Post by aeroxbud on Jan 9, 2021 18:18:22 GMT -5
Try a tea spoon of fuel into the spark plug hole. Put the plug back in and see if it fires for a few seconds. If it does, try cleaning the carb. 49ccscoot.proboards.com/thread/363
Post by gonzalo on Jan 9, 2021 19:24:52 GMT -5
Hey pinkscoot thanks for your reply, yes I took a look at Brents tutorial, great job by the way but I coldnt narrow a solution. Everything in the scoot is stock and with less than 3000km on it. I just went over for a "last try" and found that the battery is lacking power (new gel battery bought yesterday) so I removed the spark plug but couldnt make it spark. I'll try to recharge the battery tonight to keep trying tomorrow, I'm planning to recheck for spark first thing and I fear that if that doesnt work out I will have to go for the carb....
Post by gonzalo on Jan 9, 2021 19:25:50 GMT -5
Try a tea spoon of fuel into the spark plug hole. Put the plug back in and see if it fires for a few seconds. If it does, try cleaning the carb. 49ccscoot.proboards.com/thread/363Hey Paul yeah, that was my plan for tomorrow. Thanks,
Post by gonzalo on Jan 10, 2021 17:36:15 GMT -5
Hey! So today I took the carb apart and cleaned it (with vinegar, I didnt have carb cleaner). It looks quite ok. Put it all back together an I find that when I kickstart it, it runs for about 5 secs. This is almost always in the first kick (I dont have to try several times). If I turn the throttle it inmediately clogs. Tried the mix and air screws with no luck. Fuel supply to the carb is uninterrupted and working ok (I can see it throughout the transparent hose I installed).... Running out of ideas, I seem to be ver close but cant seem to nail it
Post by aeroxbud on Jan 10, 2021 17:47:59 GMT -5
I'm guessing it's a manual choke. The Choke circuit has very small galleries. I would pass a wire through it to make sure it's clear. Would be worth going through the no start guide. 49ccscoot.proboards.com/thread/647?page=1
Post by gonzalo on Jan 10, 2021 19:01:23 GMT -5
I'm guessing it's a manual choke. The Choke circuit has very small galleries. I would pass a wire through it to make sure it's clear. Would be worth going through the no start guide. 49ccscoot.proboards.com/thread/647?page=1Hey Paul I've tried it, I wouldn't have gotten so far if it wasn't for it ,,,😁😁😁 I've learned that I don't have a manual choke but an automatic feeder, I've just opened it and sprayed a little wd40 in the moving part of the needle and in the conduct (it came out in the venturi so I know it isn't clogged). Electrical connections seem to be ok. I'll let it rest until tomorrow just in case...
Post by aeroxbud on Jan 10, 2021 19:18:32 GMT -5
Connect the choke up to a positive and negative directly to the battery. Measure the before, and after to check it.
Post by gonzalo on Jan 12, 2021 13:26:58 GMT -5
Hi! So after disassembling the enritcher I found that the needle was kid of jammed. A little bit of carb cleaner and presto. The scoot starts (and keeps running)with one kick nice and easy.
One thing though, I have to give it almost full throttle for the wheel to start - slowly - spinning. I guess there's something stuck in there (I don't even know if the transmission oil was ever changed)
Post by aeroxbud on Jan 12, 2021 14:21:50 GMT -5
That's great. If it's got really stiff clutch springs fitted. It will do that. It's because most performance pipes only work at high revs. I would give the CVT a once over anyway.
Post by gonzalo on Jan 12, 2021 15:59:24 GMT -5
Hey Paul, yes I'm learning about the cvt in order to being able to fiddle with it. In the mean time, after a few minutes, it started to loosen up, at least if I sit on it and rev it to the max, it starts moving slowly...
So anyways, thank all of you very much for the help. I'll keep posting!
