Post by milly on Feb 1, 2021 15:31:10 GMT -5
What happened to the Milly that was going to slow down, and take it easier? Just woke up after a long kip π
Post by milly on Feb 6, 2021 11:13:08 GMT -5
Well started putting it back together today all went ok. I shall finish it tomorrow hopefully then get on with the new side panel and spray it up.
Post by milly on Feb 7, 2021 13:09:07 GMT -5
Well inbetween things I got the gear selector on and new panel sprayed.
Post by aeroxbud on Feb 7, 2021 13:48:37 GMT -5
With a bit of instruction from a little helper I bet. π
Post by milly on Feb 7, 2021 15:54:44 GMT -5
No to cold for her over garage today π
Post by milly on Feb 11, 2021 15:43:09 GMT -5
Inbetween many other things in life it is now running fine road tested her in 21f today was a little bit cold with that damn wind blowing a hooley Sounds ok to me
Post by aeroxbud on Feb 11, 2021 16:34:57 GMT -5
Sounds sweet. π
Post by pinkscoot on Feb 11, 2021 17:04:07 GMT -5
Gotta love the sound of a big 2 stroke.
Post by oldgeek on Feb 11, 2021 17:32:07 GMT -5
Yeah, sounds lovely! Good job Milly. pinkscoot you should cut yours down, they look cool as hell!
Post by pinkscoot on Feb 11, 2021 18:33:16 GMT -5
I'm thinking about it as I see Milly's
Post by milly on Feb 15, 2021 16:23:51 GMT -5
Today I changed the side panel for the newer one with vents in it from the lml 4t. Needs a bit more fettling but do that tomorrow also changed the restrictive air filter and changed main jet from 92 to 98 not surprised it was a bit stutters with a 92. Spun out on it but rain soon stopped play no coat on will check plug in morning.
Post by milly on Feb 18, 2021 16:41:24 GMT -5
Glad I just read my last comments have not checked plug yet. Today i cured the slow air leak with a bottle of soapy water to find it. Popped the bead and rubbed down the inner sidewall on rim in one spot where paint had chipped off. Now holding air. Need to make some minor workings on the side panel so it doesn't pop off on the bottom front to tomorrow when I have checked colour of plug.
Post by milly on Feb 19, 2021 11:36:20 GMT -5
Post by aeroxbud on Feb 19, 2021 15:56:15 GMT -5
I'm sorry Milly, but your in a garage. And can't find a plug socket! As your teachers used to say. "Must try harder. C-"
Post by milly on Feb 19, 2021 18:40:04 GMT -5
I'm sorry Milly, but your in a garage. And can't find a plug socket! As your teachers used to say. "Must try harder. C-" Ah I knew where mine were a 100yd walk one way to look and 200 yd the other to get the keys in the rain which was torrential all day. Courier said he never met any down Portsmouth way or Kent where he had come from till he hit Swindon on way back. We can't even get to town due to flooding. Not that I need to till tomorrow. Plus the mechanic don't use that size on modern carsπ
