vacationer
On Vacation
Post by vacationer on Jan 7, 2021 11:41:33 GMT -5
So in the process of upgrading my magneto setup, my pulse coil has naturally been coming in and out a lot. But it seems like all that screwing and unscrewing of the bolts has stripped the threads. Make sense since the metal (aluminum, I believe) is super soft, but now I need to fix the issue. First thought was to get a tap for the next size up (m6) and cut my own threads. However, I have no experience tapping and I'm worried that I'll just end up making bigger and equally useless holes.
Any advice?
Post by aeroxbud on Jan 7, 2021 12:02:11 GMT -5
If your not sure. It may pay to take it to a garage and get them to fit some sort of insert. It wouldn't cost too much for them to helicoil it.
Post by repherence2 on Jan 7, 2021 16:11:57 GMT -5
Or you could replace the bolt with a stud and nut. Install the stud with loctite.
vacationer
On Vacation
Post by vacationer on Jan 7, 2021 18:05:52 GMT -5
repherence2 I've been researching for hours and that solution never came up but it makes perfect sense to me. Are there some hidden cons to this method?
