Post by yaboytony on Jan 10, 2021 13:42:09 GMT -5
Does anyone know what the stock clutch spring rpm engagment is? 1500 or 1000? Thx
Post by pinkscoot on Jan 10, 2021 14:59:23 GMT -5
Generally 2000-3000 rpm+, just a little over idle. I depends on if it's a 2T or a 4poke. less than that may mean a problem with the clutch.
Post by Zino on Jan 10, 2021 21:26:43 GMT -5
stock clutch springs are equivalent or just a notch lighter tension to most aftermarket soft tension springs .
If you are getting a 2 stroke pipe Street pipe non expansion stock low or medium strength work well Expansion pipe budget to mid grade medium to hard springs Expansion pipe high End high revving Hard springs
If you go with the more extreme pipes you may want to upgrade to a adjustable clutch so you can dial in the tension right to the pipes narrower power band.
Post by SMALL CC TEK on Jan 11, 2021 13:09:02 GMT -5
They vary so much but of the 100's i worked on just 0ver 1000 they all start to lock up . That all depends on the tune of your motor and weights .. And that color code thing is a joke each manufacturer has a different color or answer .. Contra springs should be sold by spring pressure and length that's how i do it way more accurate ...
Post by pinkscoot on Jan 11, 2021 15:42:32 GMT -5
Malossi doesn't just color codes but gives you the gauge of the spring because the thicker the gauge the stronger the spring. If you go Here: wemalossistore.blob.core.windows.net/files/montaggio/pdm/7311401.pdf at the bottom of the manual they list all of the springs they sell. On the left side they give you the gauge of the spring. As for contra springs they give you what you need to know which spring is stiffer with this chart: As for other manufactures if you dug deep you could probably get the information for comparing their springs. What is more important is understanding what the springs do and how to use them to tune. Here is a great explanation that a member put together: 49ccscoot.proboards.com/thread/8213/cvt-operational-theory
Post by SMALL CC TEK on Jan 12, 2021 2:15:20 GMT -5
That's a nice cheat sheet . I have a spring pressure gauge i use. It makes tuning a lot easier or just plain shimming a old spring worth doing cause you don't have to do it 100 times lol
Post by FrankenMech on Jan 12, 2021 2:21:17 GMT -5
That's a nice cheat sheet . I have a spring pressure gauge i use. It makes tuning a lot easier or just plain shimming a old spring worth doing cause you don't have to do it 100 times lol Where did you get the spring pressure gauge?
Post by SMALL CC TEK on Jan 12, 2021 20:12:51 GMT -5
That's a nice cheat sheet . I have a spring pressure gauge i use. It makes tuning a lot easier or just plain shimming a old spring worth doing cause you don't have to do it 100 times lol Where did you get the spring pressure gauge? Jegs just make yourself a base for the spring to set on ,It's just a valve spring tester ! You can buy one but a dedicated contra spring tester is like 250 / 400 bucks. This does the same thing you just use your press or drill press or even make a lever style fixture press from wood, when i got mine it was 80 bucks or so that was 5 years ago..
Post by FrankenMech on Jan 12, 2021 21:34:43 GMT -5
Thanks! I will look up the Jegs unit and see if I can duplicate something. I am always looking for Metrology ideas. I have both a drill press and a small home made 3T hydraulic press. Someday I may even have an arbor press, I keep looking at them and drooling. You know how that is...
I see that it is just a hydraulic cylinder and a pressure gauge: I have a big lathe that just needs to be powered up.... I love tools, I am currently getting pieces together to make a hot wire cutter for foam, rope, etc, etc. I bought some nichrome wire that may work and I have a nice 20A variac with various springs My problem is having enough space to store and use the tools I have plus the physical ability to use them now that I am OLD and fucked up.
Post by 90GTVert on Jan 13, 2021 6:09:40 GMT -5
I used a 300lb capable shipping scale (bathroom scale would work) and a drill press to check some springs. I don't think it's the greatest thing ever. A little too easy to make results vary, but it can at least get you some ballpark stats and you can choose whatever heights you want to test at. www.youtube.com/watch?v=mSR04OjP6fU
Post by SMALL CC TEK on Jan 13, 2021 18:19:38 GMT -5
As long as you compile your data using the same equipment and techniques ,no matter if it's accurate to the 10th or not your way ahead the game .
