0weng
Post by 0weng on Jan 16, 2021 12:39:21 GMT -5
Stg6 display fuel gauge wiring installation, *question. It always read 100%, it says on the manual to just ground the black wire. It shows the correct fuel level briefly and then it'll proceed to go up to 100%. Stock fuel gauge shows the correct fuel level as shwon on the video. Steps done: -Connect the black wire(from the s6 display) to earth: it shows %100 -Connect the black wire (from the s6 display) to green wire(green from the harness) : it shows 100% Sorry, i,ve got next to none knowledge about wirings lol Video link: drive.google.com/file/d/13g5KXQdG4V5yynIcsg75Am0ES87jYldl/view?usp=drivesdk
Post by aeroxbud on Jan 16, 2021 13:03:39 GMT -5
I think you have to set the resistance to match your fuel sender.
0weng
Post by 0weng on Jan 16, 2021 13:39:30 GMT -5
I think you have to set the resistance to match your fuel sender. I did try both settings, it didnt help.
pewpew
Post by pewpew on Jan 16, 2021 16:53:30 GMT -5
Stg6 display fuel gauge wiring installation, *question. It always read 100%, it says on the manual to just ground the black wire. It shows the correct fuel level briefly and then it'll proceed to go up to 100%. Stock fuel gauge shows the correct fuel level as shwon on the video. Steps done: -Connect the black wire(from the s6 display) to earth: it shows %100 -Connect the black wire (from the s6 display) to green wire(green from the harness) : it shows 100% Sorry, i,ve got next to none knowledge about wirings lol Video link: drive.google.com/file/d/13g5KXQdG4V5yynIcsg75Am0ES87jYldl/view?usp=drivesdkI dont think it works with the stock fuel level sensor, i had the same problem.
Post by ThaiGyro on Jan 16, 2021 20:20:20 GMT -5
I know little about Stage 6 stuff...they use others to make their gear...but if you can find the ohm range for your scooter...and the S6 sender... You just might have a signal that ends, where the other begins. It also might not recognize the signal range at all.
Sorry for the vague answer, but electrons and their programmers are a strange lot.
