Post by Deleted on Jan 17, 2021 1:26:25 GMT -5
Hello All, I put on the street exhaust with no major problems, but I do have a lingering question. The pipe comes in two parts which are held together with a spring. Is there supposed to be a gasket or an o'ring that goes between these pieces? Or do they just sit there as is? Appreciate any info. I've been all over the net trying to find the answer, but no luck thus far. This is an older photo of the connection. I already yanked that restrictor out. The down pipe goes into this piece.
Post by aeroxbud on Jan 17, 2021 4:45:30 GMT -5
If it's anything like the Yasuni, that used a similar system, it should be fine
Post by Deleted on Jan 17, 2021 8:58:25 GMT -5
aeroxbud good deal. I was slightly concerned about any gaps/leak sources. I guess there would be some mention somewhere online if it was an issue or they had intended for it to have gasket.
