Post by jglen00 on Jan 22, 2021 18:29:54 GMT -5
Hello to all,
I'm trying to get my D1E41QMB Qingqi 50cc running again. I tore everything apart after the engine shut off from lack of oil. After everything was taken off I'd decided to just go with premix. I broke the jug on accident and I had alot of trouble getting the new piston into the new jog. Turns out it's hanging up in the crankcase. Any quick answers? I've provided a video to further illustrate
Many, many thanks
Post by aeroxbud on Jan 22, 2021 19:36:44 GMT -5
You will have to change your YouTube settings from private for us to view it. I don't really get why the piston would catch on the cases, as it's much smaller.
Post by jglen00 on Jan 22, 2021 19:54:39 GMT -5
Yes will do. Thx!
Post by jglen00 on Jan 22, 2021 20:06:22 GMT -5
Post by jglen00 on Jan 22, 2021 20:13:03 GMT -5
Sorry I left a few details out. I removed the piston from the connecting rod where I discovered it's the crankshaft that's hanging up. When I crank it by hand it will turn smoothly a couple of rotations then I encounter resistance. I can still turn it, it's just more difficult. The starter and battery can't keep up with whatever is catching
Post by aeroxbud on Jan 23, 2021 5:34:07 GMT -5
When you had taken the piston off. Did the crank spin freely by hand, with no grinding?
Post by captincvmn on Jan 23, 2021 6:39:14 GMT -5
Perhaps some debris fell down into the crankcase. It sounds like it is just coming up on the compression and stopping. If you think it is piston to crankcase interference remove your spark plug and crank it again. If it’s compression it’ll crank freely. If it’s mechanical resistance somewhere it’ll still crank hard.
Post by jglen00 on Jan 23, 2021 13:57:46 GMT -5
When you had taken the piston off. Did the crank spin freely by hand, with no grinding? No sir it had resistance, not grinding though
Post by jglen00 on Jan 23, 2021 13:59:10 GMT -5
Perhaps some debris fell down into the crankcase. It sounds like it is just coming up on the compression and stopping. If you think it is piston to crankcase interference remove your spark plug and crank it again. If it’s compression it’ll crank freely. If it’s mechanical resistance somewhere it’ll still crank hard. I did remove the spark plug and it cranked freely with no resistance. Could you please explain what this means?
Post by jglen00 on Jan 23, 2021 14:01:45 GMT -5
Sorry I haven't responded. I need to turn on notifications on my browser. Thank you for your input
Post by captincvmn on Jan 23, 2021 14:47:09 GMT -5
Perhaps some debris fell down into the crankcase. It sounds like it is just coming up on the compression and stopping. If you think it is piston to crankcase interference remove your spark plug and crank it again. If it’s compression it’ll crank freely. If it’s mechanical resistance somewhere it’ll still crank hard. I did remove the spark plug and it cranked freely with no resistance. Could you please explain what this means? If it cranked freely then it is simply the compression inside the cylinder that is causing your hard cranking. Weak battery or poor connections to the battery and solonoid. Might just be a tough bike to crank.
Post by jglen00 on Jan 23, 2021 16:03:38 GMT -5
I don't think it's the battery. It's fully charged and hooked up to a float. I considered that it wasn't strong enough but it started before it died on me with the same battery
Post by pinkscoot on Jan 23, 2021 19:04:17 GMT -5
What is your compression?
Post by captincvmn on Jan 23, 2021 20:33:43 GMT -5
Oh oh I know what it is!!
If the video is taken from above the engine looking down at it, front of the scooter at top of frame, the engine is spinning backwards. It appears as if the top of the flywheel/fan is going towards the rear. This would be backwards. Positive and negative are switched on the battery.
Bam!
Post by jglen00 on Jan 23, 2021 21:44:55 GMT -5
Oh oh I know what it is!! If the video is taken from above the engine looking down at it, front of the scooter at top of frame, the engine is spinning backwards. It appears as if the top of the flywheel/fan is going towards the rear. This would be backwards. Positive and negative are switched on the battery. Bam! Let me check this. I kid you not I said to myself why is it spinning backwards. I thought it might be because it was 2t lol
