Post by kyledude on Jan 26, 2021 22:41:37 GMT -5
Scooter has been sitting for 2 years. Starter button is not working. I can jump the starter coil and it will kick over but no spark to plug. Trying to test the relays and not getting anything not sure if I’m doing this wrong. Any info would help thanks
Post by wiscootsin on Feb 22, 2021 23:32:55 GMT -5
you can jump a starter that will turn over without having the "run" switch (or keys) on.
My guess might be that the starter button is bad or just corroded a bit. Or possibly, just the "run" switch is corroded, resulting in the starter button not doing anything. I would say take those two switches apart and clean them up. Verify continuity and the signals they send.
