Post by 2StrokinDane on Feb 3, 2021 12:32:37 GMT -5
Hello fellow scooter enthusiasts ! Im wondering what igition timing to run on my scoot, its and Stage 6 RT 70cc build, however, even though its a 70cc, 47.6mm cylinder, its running a 44? mm cranck, with 85 conrod. (there is some kind of spacer on the underside of the cylinder) some have said 1.4mm before TDC (same as stock cranck strok), and well i dont really seem to find good answers on the webs Im running italkit innerotor igniton btw. Any advise would be appriciated, currently its running 1.4 before TDC, but if itl damage anything, or just cause loss of power, it would be a shame Best regards
pewpew
Post by pewpew on Feb 3, 2021 18:00:40 GMT -5
The stage6 rt 70cc wont work with a 44mm stroke crank. It has the spacer below the cylinder stock. It would be 80cc with 44mm crank
Post by 2StrokinDane on Feb 4, 2021 2:11:13 GMT -5
Well from what i understand it uses the spacer, in order to be able to run with the longer stroke and still keep the intended stroke of the stock engine,
pewpew
Post by pewpew on Feb 4, 2021 11:25:33 GMT -5
Well from what i understand it uses the spacer, in order to be able to run with the longer stroke and still keep the intended stroke of the stock engine, I have used those kits. The spacer is there so it doesnt have to use the stud bolts that they normally use.
