af18 125cc
Feb 12, 2021 16:19:34 GMT -5
via mobile
Post by ADLY 2Stroke on Feb 12, 2021 16:19:34 GMT -5
I have a honda dio af18 125cc engine and I want to adapt it to a 50cc adly panther frame, who can help me
Post by jbjhillbilly on Feb 14, 2021 13:50:55 GMT -5
Well, any decent welder can do the job.
You should compare the two mounts side by side. Not sure what motor the Adly uses, but grafting the Elite mount to why I suspect is a Minarelli mount is doable.
Really it’s the shock that will be the challenge. Mounts will likely be in different places and might need a new upper mount welded on.
Post by wiscootsin on Feb 19, 2021 20:09:47 GMT -5
yeah that Adly should be a standard minarelli mount.
Just be sure you check clearances of intake, carb, airbox stuff. Might need more frame mods to fit.
Post by repherence2 on Mar 5, 2021 17:58:49 GMT -5
You should just put that af18 in a 4 stroke scoot. That way, no need cut and weld the motor mounting brackets. Af18 wolf in 4-stroke sheep clothing... Sleeper.
Post by Deleted on Mar 5, 2021 21:16:26 GMT -5
yeah that Adly should be a standard minarelli mount. Just be sure you check clearances of intake, carb, airbox stuff. Might need more frame mods to fit. Yep. Standard minarelli. Nearly all Adly bikes use it. Even though I ride an RT, all of my parts are stamped JET50. Seems like the only real differences are frame variants and plastics. Almost all the guts are same across the models
