Post by xtremrox on Feb 13, 2021 10:20:40 GMT -5
Im building airsal 88xtrem aerox and theres almost nothing of airsal 88 scooters anywhere. Does someone here have any experience of this cylinder?
Post by aeroxbud on Feb 13, 2021 13:57:05 GMT -5
Welcome to the forum. I have no experience with this kit. But it looks fast. Are you running the matching stroke crank? I'm guessing you have to machine the cases?
Post by xtremrox on Feb 14, 2021 14:55:24 GMT -5
Welcome to the forum. I have no experience with this kit. But it looks fast. Are you running the matching stroke crank? I'm guessing you have to machine the cases? Yea i did the sleeve part myself and will take the crank area for machinig next week and yea i have airsals own 45mm crank
Post by aeroxbud on Feb 14, 2021 17:00:25 GMT -5
Will be great to see how it compares to the other high end kits. Airsal kits are normally good value for the performance.
Post by xtremrox on Feb 15, 2021 15:01:29 GMT -5
Will be great to see how it compares to the other high end kits. Airsal kits are normally good value for the performance. Yea and i have seen over 25hp dynosgraphs from few aeroxses and minarelli copy scooters whit xtrem 88 my target is to hit 140kmh/86mph and 5.5 0-100kmh/60mph
Post by 808ministroke on Feb 19, 2021 7:22:45 GMT -5
if thats your goal for 86 top speed and 5.5 seconds i would deff. look into porting that bad boy. i have never owned this exact kit but it is similar to the mallosi 50mm hyper race bores with 7 transfers except airsail has only 6 tranfers. i had one for minarelli except standard stroke that was ported and the 86cc vers unported , According meted noticeable difference and I think there's even more Room to enlarge or white in the exhaust on this kit
Post by xtremrox on Mar 5, 2021 12:47:27 GMT -5
if thats your goal for 86 top speed and 5.5 seconds i would deff. look into porting that bad boy. i have never owned this exact kit but it is similar to the mallosi 50mm hyper race bores with 7 transfers except airsail has only 6 tranfers. i had one for minarelli except standard stroke that was ported and the 86cc vers unported , According meted noticeable difference and I think there's even more Room to enlarge or white in the exhaust on this kit Actually this airsal 88 has 7transfers and is close to the healthy limits from factory 96.5 or 98.6% wide exhaust port i cant remeber 196.6° of exhaust duration 129-133° of transfer duration
Post by xtremrox on Mar 5, 2021 12:58:54 GMT -5
Heres my setup rn -Stock 88 xtrem -airsals own crank -most 86-90cc exhaust -28vhst br by dellorto whit 145 main jet And 40 pilot jet -vforce 3 by s6 -tpr360 manifold -mvt premium ingition -lafuria rossa variator set whit 5.5g rollers -torque control clutch -malossi red torque spring -s6 red clutch springs -wingbell clutch bell by s6 -polini 13/44 primary transmission -s6+%40 pump
First start will be next week and then i have some 3 weeks before the wheater is good for riding and my to do list for that time is
-polini bearing transmission cover -s6 cnc clutch bell -new air filter by pippercros -gas shock for the rear
