mybad
Scooter Enthusiest from Salem Massachussetts USA, SR50 Malossi Replica ,Derbi Predator,and bunch of
Post by mybad on Feb 16, 2021 21:27:14 GMT -5
Hi guys. Just curious if anyone has been able to mod a 90cc cylinder ,piston and head on a super 8 2 stroke ?. I know it isnt a simple task but is it possible or has it been done ? Thanks for any input on the topic in advance .
Post by geoffh on Feb 17, 2021 15:24:46 GMT -5
With enough time and money of course it,s possible,much better to stick to the normal 70cc upgrade or move up to larger platform.
Post by aeroxbud on Feb 17, 2021 19:38:07 GMT -5
I had a look, but can't find any 90cc cylinders that were designed to fit the super 8. It could be done still. But makes it a whole lot harder. You would need to find a kit that was close, with matching stud placement. Then you would need to bore the cases. And any machining to match the bore. Seems a lot of work. Would be much easier just to buy a platform with parts availability already there.
Post by 190mech on Feb 17, 2021 20:07:11 GMT -5
From previous Super 8 owners posts,the limiting factor on the engine is the very short final gearing,,No aftermarket up gearing was available at that time,so a stronger engine could'nt get that power to the road.. As the guys above say,just get a good quality 70cc kit and enjoy the ride!
mybad
Post by mybad on Feb 18, 2021 22:30:05 GMT -5
Yeah thank you guys. I have the Mallossi cast iron 73cc kit on it now. With Leo Vince TT exhaust and 19mm carb . At the moment I have the engine out of it because I'm having a hell of a time finding Crank seals and a complete gasket kit so i can split the case and replace all gaskets because the scooter barely has 1000 miles on it but has been sitting since 2013 . Anyone recommend a usa seller with fast shipping that may have these parts ?
Post by aeroxbud on Feb 19, 2021 9:52:46 GMT -5
mybad
Post by mybad on Feb 20, 2021 17:30:34 GMT -5
Thank you so much for the help and the links. I'll post in builds when I get started .
