Post by retirednow on Oct 26, 2011 21:18:49 GMT -5
Thinking about replacing stock CDI on Wildfire 50 with a "performance" CDI. Opinions?
Post by Fox on Oct 26, 2011 21:55:23 GMT -5
Post by 90GTVert on Oct 26, 2011 22:30:34 GMT -5
If the stock CDI is rev limited, good idea. If the stock CDI is not limited, expect no to slight gains. Some of these aftermarket units don't actually do anything different and it seems like a crap shoot sometimes guessing if you'll end up with one that actually changes the timing. I'd think those adjustable units would be more likely to do something, but I'm not sure. Also, advancing ignition timing can require higher fuel octane.
Post by retirednow on Oct 27, 2011 15:40:32 GMT -5
Thanks for the input so far. I'll probably replace over the winter...getting too cold to ride for now anyway believe I have an iridium plug~have to check-it might be in my Baja Doodlebug.
Post by speedy1125 on Oct 28, 2011 4:43:44 GMT -5
Post by craisin on Dec 2, 2011 21:17:43 GMT -5
if you want to advance your ignition you could slot the holes on the pick up. Then you could put it back to original if there is no improvement.
There are AC CDIs and DC CDIs.
I am told that DC CDIs produce 8-10% more power.
Myself I took out the stock rev limited DC CDI that had 6 wires and replaced it with a AC CDI with an advance curve built in. Because I
Post by Mech Warrior on Jul 17, 2020 11:02:35 GMT -5
My IF you are building a really high revving bike above 14k RPM i would definitely recommend in buying a solid brand name cdi such as malossi scooterpartsco.com/malossi/01-malossi-master-part-list/malossi-cdi-for-genuine-scooters <Just a example of a quality cdi comapred to buying the cheap blue ebay cdi.When you get into higher rpm and want quality controlled spark with a solid proven consistency of performance malossi is the way to go.
Post by FrankenMech on Jul 18, 2020 12:33:37 GMT -5
A post from 2011, Really?
Post by Mech Warrior on Jul 18, 2020 12:46:25 GMT -5
Just checking.
Post by Mech Warrior on Jul 18, 2020 12:46:54 GMT -5
Also trying to get post count up lol. I would comment on a post from 1806.
Post by FrankenMech on Jul 18, 2020 15:22:08 GMT -5
Don't do that.
Post by GrumpyUnk on Jul 19, 2020 8:56:57 GMT -5
Please stop. I don't look at posts that are historical unless searching for an answer.
Having posts with the 'new' flag with the purpose of increasing your YOUR!!! post count is wasting EVERY ONE ELSE's time.
Just take your time, and post, if you are ADDING TO THE CONVERSATION, on newish posts. If you have enough to add, your count will go up faster than you realize.
Again, please do not post to revive old threads and take up MY time anyway, or I will ignore any posts that you make if I see your name. "the sky is falling..." not. "Wolf! Wolf!" ... can wear out a welcome. tom
Post by bullybike on Jul 29, 2020 22:15:58 GMT -5
imma do it 😈 Running a purple Kitaco "adjustable" AC cdi im pretty happy with got quite a few hot miles on it. It basicly cool because you turn the resistor all the way and you get i think 18* advance on a after 2000rpm. So you can have a nice little bit of advance and also easy startup and idle. it also dosent cut revs when i go downhill fullbore, so fyi at your own risk. for $20 i recomend it
Post by bullybike on Jul 29, 2020 22:28:43 GMT -5
P.s can i get a free star upgrade mods ⭐ *the above user (Bullybike) is not affiliated with Kitaco or any of its resellers🤣
