mybad
Scooter Enthusiest from Salem Massachussetts USA, SR50 Malossi Replica ,Derbi Predator,and bunch of
Post by mybad on Feb 24, 2021 20:51:14 GMT -5
Hi guys . I'm about to order a jet set for my Kymco Super 8 2t and SYM Jet 50 evo . Both pretty much the same engine and both have the same carb that I'm about to blink below . I am just not sure what jet set I need and dont want to order a set for the wrong carb . Can anyone help me out with an amazon link ? Or some know how on how to tell the difference . Indo know my 4 stroke sets are different . But that's about all . I am planning on upgrading to a higher end carb/intake and reeds from a different setup soon . But for now I just need a jet set for this one . Here is the 19mm 2 stroke carbs i have on both scooters . ( Need a Jet set) www.amazon.com/dp/B07MFW8S2V/ref=cm_sw_r_cp_apa_fabc_8SQ4Z241AD1SRT9ZANE8Thanks Guys
Post by geoffh on Feb 25, 2021 15:43:47 GMT -5
The only way to sure which jets you need is to strip the carb and check what you have,carb size is open to debate as people use different criteria,a standard Yamaha 50cc uses a 12mm carb and 6mm jets.
Post by captincvmn on Feb 25, 2021 17:24:31 GMT -5
Agreed That’s not a 19mm carb as far as throat size. Most likely 19mm at the end of the pipe. My stock carb on my Keeway used 6mm thread jets but the carbs vary widely. As noted above, take out what’s in it now, measure them as far as thread size, buy an assortment like Glixal has from Amazon to get started.
Post by Zino on Feb 25, 2021 19:40:40 GMT -5
mybad
Post by mybad on Jul 6, 2021 12:08:55 GMT -5
Sorry for late reply but exactly what I needed. Huge help thank you my friend.
