Ciao Ciao
Mar 3, 2021 23:42:08 GMT -5
via mobile
Post by woodini on Mar 3, 2021 23:42:08 GMT -5
Good Lord! That little motor makes a GET look like a V-Twin! 😆
Post by Lucass2T on Mar 4, 2021 2:24:54 GMT -5
That's not a good design to check the points. They must do an electronic ignition right? Yes they do. Not sure which model exactly but the ciao-mix (with oil injector) must have it. Maybe vespa bravo has it too. They also come with a variator and kickstarter. Pretty awesome little mopeds.
Post by Happypancake! on Mar 7, 2021 15:56:43 GMT -5
It ruuuuuns! And has lights. Need to fix on/off switch then buy go-fast parts .
Post by Tanuki on Mar 7, 2021 17:28:01 GMT -5
What year?
Post by Happypancake! on Mar 7, 2021 20:45:36 GMT -5
It’s 2021. Wake up! (1977)
Post by Happypancake! on Mar 15, 2021 12:55:43 GMT -5
Go “fast” parts arrived !
Post by Happypancake! on Mar 16, 2021 20:42:26 GMT -5
43mm kit
Post by Happypancake! on Mar 16, 2021 21:21:15 GMT -5
A little larger SHA. Trying to keep it reliable . Did not bore the intake any larger.
Post by Happypancake! on Mar 16, 2021 21:47:16 GMT -5
Lighter clutch
Post by Happypancake! on Mar 16, 2021 22:18:06 GMT -5
Tidy
Post by Lucass2T on Mar 17, 2021 8:14:08 GMT -5
Those nice and mild upgrades! Thats the DR kit you have there? By adding or leaving out the head gasket you can add either top speed or torque very easily. They come without one from the factory, by adding a head gasket you'll lower the compression which results in higher top speed but you'll lose some acceleration. Worked a lot on these little mopeds. They're so much fun and super cheap to maintain.
Post by Happypancake! on Mar 17, 2021 10:29:09 GMT -5
Those nice and mild upgrades! Thats the DR kit you have there? By adding or leaving out the head gasket you can add either top speed or torque very easily. They come without one from the factory, by adding a head gasket you'll lower the compression which results in higher top speed but you'll lose some acceleration. Worked a lot on these little mopeds. They're so much fun and super cheap to maintain. Yeah. Olympia kit (dr clone). And I did not put on the head gasket. There is a lot of room for porting but chose not to do it now.
Post by Happypancake! on Mar 17, 2021 13:55:57 GMT -5
Started up. Clutch springs to tight. Need to swap.
Post by dirty14 on Mar 19, 2021 11:48:54 GMT -5
I’m excited to see what you do with this thing. Never too many Vespas in Pittsburgh. Did you open the intake patch at all? I bet it’s one of the smaller ones with the size of the carb that was on it. The Olympia is a lot like a larger bore stock cylinder with boost ports. The newer dr that replaced this one has larger split transfer ports and bigger boost ports.
Post by dirty14 on Mar 19, 2021 12:10:23 GMT -5
At the 20 minute mark of this video he goes over cutting the crank for increased inlet timing. This really wakes up the Vespa motors. youtu.be/4mcr5-tuANY
