Post by fastboys on Apr 4, 2021 21:14:47 GMT -5
I have a stage 6 rt 70 on a drr quad.my son runs it wide open goes into a turn gits the throttle and it bogs. If he feathers the throttle he can make it stop. It also goes faster at half throttle then full. I thought it was too big of a main jet but so far I havent got it perfect.
df41590
Post by df41590 on Apr 4, 2021 21:31:54 GMT -5
Sounds like it's rich, may be right about the MJ being too big. What does the plug look like?
Post by captincvmn on Apr 5, 2021 7:57:30 GMT -5
What carb/ What jet?
Post by fastboys on Apr 5, 2021 8:07:34 GMT -5
Ill pull the plug when I get home. I have kept going down on main jets but I feel like I get to a spot where it gets worse. Ive played with the needle a little but I just cant get it perfect. Leak down test passed and I have 165psi compression.
Post by fastboys on Apr 5, 2021 8:49:02 GMT -5
28mm nibbi d slide 50 pilot and im down to a 108 main needle on 2nd clip
Post by captincvmn on Apr 5, 2021 9:50:44 GMT -5
I have a 70cc street race with a 19mm carb running a 80 main jet
Post by fastboys on Apr 5, 2021 17:52:27 GMT -5
Well I have always ran this setup and the only thing different about this motor is the trenching of the case. Ive only been messing with these for 2 years and im still learning.
