micky
wrenching on something
Post by micky on Apr 11, 2021 12:13:04 GMT -5
If all goes according to plan, I’m picking up an ‘08 Zuma tomorrow. Once I pick it up, I’m planning on ordering the parts. Is mid-60MPH possible with “street” parts? Or do I need to lean towards race? I’d prefer a cast iron cylinder, but don’t want to undershoot my goal. Also, would a crank upgrade be required to put me safely within the mid-60’s? How’s the Stage 6 street race cast cylinder vs the Malossi cast? Is it really better? I wouldn’t mind upgrading the crank if it’ll be a big gain. I do want this scoot to be reliable enough for a few 30-40 mile rides. Any thoughts on parts? My only other scooter was a Genuine Buddy, and parts are so limited. I didn’t have all these options. Many people are running the stage6 streetrace here in europe. it is hard to find another cast iron cylinder with a wide powerband and good top speed that is made for everyday use for the price of the streetrace cylinder. ofcourse you can buy a polini corsa or a malossi sport and port it. but the streetrace is strong out of the box with a low price for its class.
Post by repherence2 on Apr 24, 2021 17:19:35 GMT -5
Buddy’s have the small tires right? Most guys I know with those size tires on Elites start at ~9.0:1 and only go lower from there. My buddy’s elite with a Corsa and a pipe with 8:1 gears will do 70mph. A lot of guys run 7:1 as well. They being said, for our tastes around here, the latter may be a bit extreme lol. Yes. Small tires. 90/90-10. That said, I dont know if gearing exists for the bike that’ll go lower then 9.5:1. I really don’t want to rosk losing much low end power, so my biggest concern is that the 9.5:1 will be too aggressive. I do have lots of hills/mountains. Maybe a 90cc engine swap would suit your liking. It wont be a high revving screamer, but you get the low end grunt. Spin less rpm, less wear and tear than spinning over 10k rpm all the time.
Post by lunatuck on Jun 7, 2021 19:17:53 GMT -5
Got my Zuma. This thread is back!
Post by Zino on Jun 7, 2021 19:24:52 GMT -5
What year zuma did you pick up ?
Post by lunatuck on Jun 7, 2021 19:44:54 GMT -5
What year zuma did you pick up ? It’s a 2003, but only 2k miles.
Post by Zino on Jun 7, 2021 21:13:36 GMT -5
I have a 2004 They are a solid platform .
2002-2005 The bare minimums you have to upgrade if you kit it and pipe it The 14.66 gears have to be changed out you can go as low as 14/42 . The Clutch is 2 shoe which has a hard time keeping up with more power so that has to be swapped out . The torque driver has dual angle so it has a funny shift .
The good things compared to 2008-2011 The Carb is adjustable both at the needle and the idle mixture so you can upjet it Mikuni Jets 11/22 jets fit something between 85-95 works well . The stock pipe is Cat free so you dont have extra holes in your air box to plug
Post by Kenho21 on Jun 8, 2021 7:55:02 GMT -5
Got my Zuma. This thread is back! I’ll be paying attention.
