Post by dukeofspeed on Apr 7, 2021 17:31:04 GMT -5
I have just bought my first scoot, its a non runner at the moment but I can't work out how the lights work. There is no light switch or high/low beam etc. Its got all of its original handlebar switches on it, but where other bikes have buttone etc mine has blanking plugs! I have seen pics of other models e.g. speedfight and they have switches and flash button etc. I think mines an 'off road' model. Please if anyone could explain to me I would be most grateful. Thanks
Post by aeroxbud on Apr 7, 2021 23:21:38 GMT -5
Welcome to the forum. Most newer scooters don't have an on/off switch. The lights are on all the time. They won't come on till the scooter is running. The high/low beam should be controlled by a switch on the left bar.
pewpew
Post by pewpew on Apr 8, 2021 8:44:18 GMT -5
I have the same scoot, it only has the starter button on the right side but should have a high/low beam switch on the left side
Post by aeroxbud on Apr 8, 2021 13:14:21 GMT -5
In this video, you can clearly see it's the blue switch.
Post by dukeofspeed on Apr 9, 2021 23:37:48 GMT -5
Thanks for your responses. Mine doesn't have a blue switch it is blank where that one is, it just has the indicator switch and cancel
Post by aeroxbud on Apr 10, 2021 4:10:39 GMT -5
That's strange. Can you post a picture of the controls?
Post by dukeofspeed on Apr 10, 2021 8:13:08 GMT -5
Post by dukeofspeed on Apr 10, 2021 8:17:33 GMT -5
The ignition key switch only has on or off positions, so it makes sense that lights will be on all the time
df41590
Post by df41590 on Apr 10, 2021 10:37:54 GMT -5
If it has bulb/s for headlights they likely only come on when engine is running.
Post by dukeofspeed on Apr 10, 2021 10:56:30 GMT -5
If it has bulb/s for headlights they likely only come on when engine is running. Yes it has the two headlights, but it appears I don't have a high/low beam switch
df41590
Post by df41590 on Apr 10, 2021 14:46:16 GMT -5
Is there a connector that nothing was plugged into up by the handle bars? How many wires are in the head light connector by the headlight housing, 2 or 3?
Post by aeroxbud on Apr 10, 2021 16:54:43 GMT -5
What does the button on the top left do? You might have to undo the left switch gear and have a look.
Post by dukeofspeed on Apr 10, 2021 19:41:37 GMT -5
What does the button on the top left do? You might have to undo the left switch gear and have a look. The left side has horn, indicators and indicator cancel button. The right side has the starter button
Post by dukeofspeed on Apr 10, 2021 19:45:13 GMT -5
The left side switch gear has 5 wires
df41590
Post by df41590 on Apr 10, 2021 20:32:25 GMT -5
Okay doesn't look wired for headlights on that end, likely one wire is for the horn, the other 4 are for the turn signals. Have had no luck finding a wiring diagram. What does the connector at the headlight housing where the bulbs are look like?
