Post by repherence2 on May 11, 2021 20:19:34 GMT -5
Ouch! No bueno (in it's current state).
Post by repherence2 on May 11, 2021 20:21:14 GMT -5
Take a picture of the star warsher, nice shot of the splines/teeth.
The 6 blade ninja star looking thing that seats into the aluminum drive face.
Post by jaysan on May 11, 2021 20:27:09 GMT -5
Post by jaysan on May 11, 2021 21:12:41 GMT -5
Is it possible to salvage the crank by using my old fan and ninja star looking thing ?
Post by Zino on May 11, 2021 22:32:35 GMT -5
It looks like the crank theads are ok . The stael crank has some aluminum ground in the threads If you need to you can clean them up with small diamond files .
A new variator fan and star key would be best to cut down on vibration .
Post by aeroxbud on May 12, 2021 5:25:25 GMT -5
That looks bad. You could try cleaning it up with a file. Like zino said, that variator is probably toast. And definitely replace the star washer, they are cheap.
Post by jaysan on May 12, 2021 7:27:17 GMT -5
It looks like the crank theads are ok . The stael crank has some aluminum ground in the threads If you need to you can clean them up with small diamond files . A new variator fan and star key would be best to cut down on vibration . Will file and order new parts .
Post by Zino on May 12, 2021 7:31:09 GMT -5
Dont go crazy filing the crank Just enough so the new star washer slides on and off with ease
Post by geoffh on May 12, 2021 15:11:32 GMT -5
It,s not good your outer variator plate is toast,very carefully take a small file and clean the crank splines as best you can and take some pictures of the result,your on a knife edge here so if your not sure ask before any action,having to change the crank is a major job.
Post by repherence2 on May 12, 2021 15:41:13 GMT -5
You need new star washer. The teeth on your current one are too worn down.
You can use a triangle file to try and repair the splines and remove the raised metal.
Post by jaysan on May 12, 2021 22:15:11 GMT -5
Post by repherence2 on May 12, 2021 22:38:53 GMT -5
those should work.
don't worry, you got this. i guy i know ran his 4 stroke scoot till the belt snapped. the variator assembly got so hot, the plastic on the rollers melted, the plastic fan on the drive face melted, and the splines on the crank was jacked up like yours. i told him to use a triangle file to repair the splines and take his time because i had to hit up the local shops for replacement parts.
he accomplished it. therefore, you can too. but as it was recommended, wait till you get the new star washer before you remove too much metal. the splines are already compromised. you can file and check fit with the new washer. like it's done in the hot water department where i work, "Minimize metal removal".
Post by jaysan on May 14, 2021 19:22:43 GMT -5
Ok so now scooter hits thirty eight miles and hour
New issue
Sigh
It won't maintain the speed it dies and drops to like twenty miles and hour then will climb to thirty eight again but it will do the cycle again and drop down to twenty
Post by geoffh on May 15, 2021 8:41:30 GMT -5
Have you repaired or replaced the variator,it,s the source of your problem,try it with the old belt to narrow the problem down
Post by jaysan on May 15, 2021 8:45:40 GMT -5
Have you repaired or replaced the variator,it,s the source of your problem,try it with the old belt to narrow the problem down Geoff Yes I bought everything new . I guess I will put the old belt on and see what happens
