micky
wrenching on something
Post by micky on Apr 11, 2021 11:52:14 GMT -5
I recently bought a cheap scooter because i wanted something to tinker around with + i need a tool of transportation during summer. i have owned several 2 stroke dirt bikes, street bikes and scooters thru the years and i like to work on them almost as much as i like to ride em so when this one showed on the local marketplace i jumped at it. I am on the lookout for 12inch rims right now, the balloon tires makes a comfy ride but the handling suffers alot. If the road is uneven im bouncing around like a kid on a yoga ball lol. not safe when going 60mph, almost forgot. it pulls really good after the bits i installed, im actually a bit baffled with the high top speed. 3800km on the tech so engine is in good condition i ordered a stage6 streetrace 47mm cylinder, 17.5mm dellorto, malossi front pulley with yellow spring, and polini secondary gear up kit. Along with clutch springs rollers and jets for the carb. this is not much of a project but im going to post upgrades and whatnot when i feel like it. i have been reading alot on this forum and i like the vibes so i created an account here is some pics, the fairings is kinda rough. not sure if im going to change them out or not. new gears pressed Update 21-08-26 Finally ordered some parts for my scoot. Athena crankshaft, waterpump rebuild kit, stage6 sport pro cylinder. temp meter, etc. Also got myself a polini clutch for cheap The engine will be opened up and inspected tomorrow, hopefully i will have the new parts installed before monday. i still need to make a mount for my radiator, and find a good spot for it. anyway here is some pics from today
Post by jkeney on Apr 11, 2021 12:38:34 GMT -5
Very cool!
Post by mrchilled85 on Apr 11, 2021 13:16:32 GMT -5
i had one of them pgo max's back in 2002 got to say it was such a fun scooter seem to go well for what it was tho i think panels are a bit rare to find now days
micky
Post by micky on Apr 11, 2021 13:37:21 GMT -5
front end is super light so i have to be carefull with the throttle when taking off, yea these are a blast to ride around town panels etc is easy to find around here. a complete set of plastics go for around 100 dollars. i might buy a set when im done upgrading it motor wise
Post by mrchilled85 on Apr 11, 2021 13:41:31 GMT -5
front end is super light so i have to be carefull with the throttle when taking off, yea these are a blast to ride around town panels etc is easy to find around here. a complete set of plastics go for around 100 dollars. i might buy a set when im done upgrading it motor wise oh you over in the usa ? im over the water in england they was just rare on the market for us what is a shame as had 2 pgo's one was a big max and other was a comet tho think its been a good year or so since i have seen one for sale over here yep around town they are so much fun and do wheelie very easy as mine was stock apart from exhaust and rollers then would still come up
micky
Post by micky on Apr 11, 2021 13:53:53 GMT -5
no im in sweden i thougt england had lots of scooters and mopeds. maybe you have more of the newer brands?
Post by mrchilled85 on Apr 11, 2021 14:03:27 GMT -5
no im in sweden i thougt england had lots of scooters and mopeds. maybe you have more of the newer brands? yep we have a lot of scooters and mopeds tho a lot of them are just honda , yamaha , aprilia , piaggio just pgo did not take off that well over here what is a shame as they build good fun and seem to last well as my big max lasted 5 years and done 27k miles
Post by Zino on Jun 14, 2021 23:11:18 GMT -5
micky any updates on your build I am building a genuine roughouse up which is a rebadged pgo pmx , I would like to compare notes .
micky
Post by micky on Jun 18, 2021 5:26:33 GMT -5
micky any updates on your build I am building a genuine roughouse up which is a rebadged pgo pmx , I would like to compare notes . Well right now i am converting it to liquid cooled. I bought a complete waterpump and radiator set that was taken from a yamaha aerox. I am saving up for a new crank + midrace cylinder and a bigger carb. Will post updates soon
Post by Zino on Jun 18, 2021 8:15:50 GMT -5
micky what part numbers do you have for the polini gear,polinin variator fan and malossi variator .
We have very limited info over in the states on what partswork best with the pgo set up .
Post by hippo008 on Jun 18, 2021 21:00:26 GMT -5
micky what part numbers do you have for the polini gear,polinin variator fan and malossi variator . We have very limited info over in the states on what partswork best with the pgo set up . Use buddy gears in your buddy. They will fit and should be a good gear ratio for the additional power. A good gear mod for the roughhouse is to swap on Buddy gears for the lower ratio on the 10" tire.
micky
Post by micky on Aug 27, 2021 5:15:39 GMT -5
update with pictures in original post. So today I am going to split and clean the cases, will also measure if i can fit a v-force or malossi vl-14 reed cage in my block. the screw pattern differs a little bit so i might have to make a adapter plate for it. If i have the time and things go smooth the new crank + bearings will be installed today. Still not sure where to mount my radiator, some ppl mount it where the original headlight goes. and some move it behind the front wheel. if anyone know a good spot let me know, im trying to keep it discreet so i dont get pulled over the first time i meet the troopers here is a pic of a similar scooter with radiator mounted behind the front wheel. (i like this one but im scared about small stones etc hitting the radiator) And one with the radiator inside the front headlight. Lots of fun going on this weekend / Mike
micky
Post by micky on Aug 27, 2021 5:17:52 GMT -5
micky what part numbers do you have for the polini gear,polinin variator fan and malossi variator . We have very limited info over in the states on what partswork best with the pgo set up . Sorry didnt see your post, i will have a look when i get back from the garage. / mike
Post by aeroxbud on Aug 27, 2021 6:43:55 GMT -5
The front wheel mount looks a lot better. It wouldn't be hard to make, or convert a stone guard from another bike.
Post by Zino on Aug 27, 2021 7:24:13 GMT -5
Micky Next time you pull your trans apart would you be able to measure the diameters. Is the pgo malossi front pulley 95mm or 97 mm like the minarelli ? What is the diameter of the polini variator fan ?
