micky
wrenching on something
Post by micky on Aug 27, 2021 12:32:50 GMT -5
Yeah the placement behind the wheel looks good and stealthy, i will make a mount as soon as the engine is back together Forgot to check the part nr, i can measure the polini fan tomorrow. need to flush the trans because i got water in the overflow when i cleaned the cases so i have to take take that apart and flush with new oil. I matched the cases today and cleaned off old gasgets.
micky
Post by micky on Aug 28, 2021 11:06:24 GMT -5
the engine is back together now. only to find out that i need a paper gasket instead of yamabond.. I don´t have a crank puller, anyone got tips on taking the cases apart without putting stress on the crank?
Post by aeroxbud on Aug 28, 2021 12:39:25 GMT -5
Did it have a paper gasket when you took it apart? Unless it was a thick gasket I can't see it being a problem.
micky
Post by micky on Aug 28, 2021 14:44:15 GMT -5
Did it have a paper gasket when you took it apart? Unless it was a thick gasket I can't see it being a problem. It had a paper gasket, not sure what the thicknes was. the crank wont turn when the engine is tightened up. I think the Athena crank is wider than the original one. Im going to try with a 1.2 mm gasket tomorrow
df41590
Post by df41590 on Aug 28, 2021 14:53:29 GMT -5
If you have access to a press you can press it out just make sure it is 100% supported by the case half your trying to push the crank out of. A steering wheel puller or a puller of a similar design would work if there are holes in the case that a line drawn between them would go through the middle of the crankshaft.
micky
Post by micky on Aug 29, 2021 12:29:46 GMT -5
Post by Zino on Aug 29, 2021 13:59:51 GMT -5
Looking Good . Where do you plan on Dialing your squish at ?
micky
Post by micky on Aug 29, 2021 14:21:22 GMT -5
Around 0.7-0.9mm
