Post by fastboys on Apr 15, 2021 13:36:16 GMT -5
Im running a stage 6 rt 70 on a drr quad. Any suggestions for clutch adjustment? I cannot get it to launch off the line. Im running and over range 1108 belt 3.5 rollers stage 6 clutch hard stge 6 spring red shoe springs. Im getting engagement around 7800.
Post by Zino on Apr 15, 2021 18:38:12 GMT -5
It engages at 7800 That is pretty high Do you have and expansion pipeor street style paired with your cylinder ?
What rpm does it jump to when you hit wide open Throttle and hold at ?
Does the rpm jump way up and then come down When hitting wide open?
Or does it hold and then rise when you get closer to top speed
Post by ryan_ott on Apr 15, 2021 22:43:47 GMT -5
Is your variator shimmed to get the belt as far down as possible?
