Post by aeroxbud on May 26, 2021 13:40:59 GMT -5
The stuff over here is just driven off the crank. There is a worm gear behind the stator. I have had stuff in the past which works off the throttle. If you have a splitter cable running to the pump, you have your answer.
Post by geoffh on May 26, 2021 15:09:02 GMT -5
The CG50 has a separate cover to protect it from the elements it should come straight out without fuss,but most just seal the pump end up at the pump and carb end and go premix it,s much safer in the lond run.
Post by thxcuz on May 27, 2021 0:13:48 GMT -5
One crappy paint job deserves another Now I’m futzing with the electrical I know my headlight is good, I’ve tested it with a drill battery and it lit right up, but when connected to the bike - Bubkis! I’ll have to do more investigation when I sober up. That’ll be some time in June. There is also a brown wire and a green and yellow wire that has been cut. If I’m looking at the schematic correctly it’s for the brake light switch. Tail lights, bilinkers and electric start works. The headlight does not I guess I’ll whip our my multi meter and pretend I know how to use it.
Post by geoffh on May 27, 2021 14:31:14 GMT -5
I am not sure but headlight might not work without the engine running. Thats correct for much later jogs so I would wait till its up an running.
Post by thxcuz on May 27, 2021 16:15:53 GMT -5
I got the new Piston today. The circlips went in easier than usual so I knew I was in trouble.
I cannot for the life of me get that damn cylinder on. My rings are right where they should be…it just won’t go on.
Can I get an “ARRRAGH!!!!!!” From the congregation
I’m so close. Hell, if I wasn’t a moron and busted the piston in the first place I’d be riding it by now.
Post by 190mech on May 27, 2021 17:57:11 GMT -5
Check your ring gaps!
Post by thxcuz on May 27, 2021 21:07:52 GMT -5
I have got to be the dumbest dummy in dumb town even when the ding a ling brothers- Buffon and moron circus is in town.
I put the rings in upside effin down.
Jeepers, Mary and Joseph - if I had a brain I’d be dangerous
Post by repherence2 on May 27, 2021 21:19:37 GMT -5
^^ main thing is that you learn from this experience.
Post by thxcuz on May 27, 2021 23:37:16 GMT -5
Oh, also - I almost set it on fire.
I’m not gonna say anything else about that except watch out for bare wires.
Post by thxcuz on May 28, 2021 7:06:41 GMT -5
I bet a fuse would have prevented that
Post by thxcuz on May 31, 2021 17:46:34 GMT -5
Update- No update, still ain’t starting on its own.
Will start with starting fluid.
Cleaning carb again tonight
#####30#####
Post by 190mech on May 31, 2021 19:01:54 GMT -5
Post by thxcuz on May 31, 2021 23:05:30 GMT -5
It’s soaking in carb cleaner as we speak
Post by thxcuz on Jun 1, 2021 8:48:46 GMT -5
Left overnight. You can see the crud the carb body didn’t fit in the jar but I sprayed the living daylights out of it
Post by thxcuz on Jun 1, 2021 9:52:39 GMT -5
