Post by scooternub on May 11, 2021 17:15:41 GMT -5
Anyone here with a 20-21 roughhouse and can do a full video of it? I'd like to see what it looks like under the seat compartment supposed where the 2t oil goes behind the flap door. The genuine buddy has the gas and oil fill under the seat, not sure I like that, in case any spills the seat compartment will be contaminated and smell.
Post by jkeney on Jun 30, 2021 2:24:27 GMT -5
I stink like 2 stroke no matter what I do. I wouldnt worry about the seat compartment.
Post by aeroxbud on Jun 30, 2021 7:01:30 GMT -5
snowmeiser has one. He might be kind enough to take some pictures. All my scooters apart from the first aerox had oil filler under the seat. Never had a problem with any of them like you described.
Post by Zino on Jun 30, 2021 7:03:48 GMT -5
Take both for a ride . See which one you like best .
If you dont use a funnel of some sort the roughouse oil reservoir is a trick to fill. You fill it every 4-500 miles .
I use a picnic type squeeze bottle to fill my roughhouse to avoid a mess .
Post by snowmeiser on Jun 30, 2021 21:14:22 GMT -5
Under the seat is for a helmet,there is a little door in the front down by the floorboard . You can get a quart bottle in there very carefully with a rag wrap around the filler neck in case of a mishap . If you spill some it drips down on the cylinder . But I have been lucky
