Post by scooter7878 on Jun 6, 2021 0:36:06 GMT -5
[im g]https://i.postimg.cc/xdKvg2X7/3-next-Plus-image43-2021-19454.jpg[/img][/url] 50mm cylinder,big valve head ported and polished and matched,oko 21mm flat slide carb,41 idle jet ,88 main jet,cut factory exhaust and stuffed with steal wool and welded back together, nibbi aluminum throttle grip,kenda tires,jml performance camshaft, glixal variator with 5g rollers, global performance clutch and bell,naraku v/s type belt,nibbi air filter, bobbin intake, naraku intake spacer, duplicolor metal cast purple paint job. I'm hitting 49mph flat ground slight wind but I'm still working on the tune and gears are next to come along with a naraku tranny kit. Also have a naraku no rev cdi and a nibbi high out put coil with a ngk cr8hix plug
Post by scooter7878 on Jun 6, 2021 0:38:30 GMT -5
Post by aeroxbud on Jun 6, 2021 6:48:05 GMT -5
Nice looking scooter. Love the purple paint. You should see if you can get a verified GPS speed. And add it to the speed list it's impressive performance.👍
Post by scooter7878 on Jun 6, 2021 16:46:19 GMT -5
Thanks I'm trying to get my gear set first I should pick up a few more mph with it and year the paint job could came out better theres a few blemishes but first one not too bad the duplicolor metal cast paint is awesome it's like a trans paint u got to paint over chrome or polished bare metal or they make a base coat silver u can spray on first on non metal parts ny next paint job will be a lot better
