Post by nuckingfuttz78 on Jul 7, 2021 1:46:05 GMT -5
I bought a Baja sc50 with only 500 miles on it and it starts runs great but has no power I can't even go up a hill no power whatsoever what do I do
Post by scooter7878 on Jul 7, 2021 5:53:21 GMT -5
Is it 2 or 4 stroke? Dirt things to check are clogged jets and the cvt take the cover off and run it in the high stand with wheel off ground and watch belt travel. At idle it should be all the way down in front pulley and at top of rear pulley as u give throttle the belt should move up the front and down the rear pulley at wot the belt should be close to top of front pulley. If ur capable remove and clean carb. That's about as much info I can start u without knowing what motor and a little more info on how it feels throughout the throttle range
Post by nuckingfuttz78 on Jul 10, 2021 22:15:05 GMT -5
It's a four stroke. I haven't taken the CVT cover off yet. I just cleaned the jets.
Post by scooter7878 on Jul 11, 2021 2:33:51 GMT -5
Lmk how u make out
Post by scooter7878 on Jul 11, 2021 2:35:13 GMT -5
Also probably before u even do cvt check the valve clearance there's videos on it if u have any questions feel free to ask
Post by nuckingfuttz78 on Jul 11, 2021 11:08:42 GMT -5
Ok I took CVT cover off it's operating properly. And my valves are set at .004". It runs and will move when I give throttle. But it's gutless and I can't reach max mph
Post by scooter7878 on Jul 11, 2021 13:01:00 GMT -5
Compression check
Post by scooter7878 on Jul 11, 2021 13:03:50 GMT -5
If low compression put little oil down spark plugs hole and recheck compression if it raise up a good bit it's ring issues if not valve train. Check the cam timing or leaking valves.
