Post by lunatuck on Jul 13, 2021 8:37:40 GMT -5
Anyone have any experience with this reed valve? I currently have a Naraku with fiberglass reeds and also experience a little low end flutter that I would normally think it jetting, but I can’t tune it out. It’s at about 1/4 throttle, but pilot is correct and needle is lowest setting.
I see a lot of dirtbike people say the VForce 3 gave crisper low end and felt like their low end jetting cleaned up. Wondering if this reed block could be my solution.
pewpew
Post by pewpew on Jul 13, 2021 9:46:00 GMT -5
Anyone have any experience with this reed valve? I currently have a Naraku with fiberglass reeds and also experience a little low end flutter that I would normally think it jetting, but I can’t tune it out. It’s at about 1/4 throttle, but pilot is correct and needle is lowest setting. I see a lot of dirtbike people say the VForce 3 gave crisper low end and felt like their low end jetting cleaned up. Wondering if this reed block could be my solution. They are probably the best reeds that wont need any modifications to the cases. But be sure that you dont have any eletrical problems that can cause backfire because even 1 backfire can shatter the reed cage
Post by 808ministroke on Jul 16, 2021 2:58:13 GMT -5
I've recently upgraded to these and and I think my 1st ever I think my 1st ever set of aftermarket reads was the naroku big valve Set you're speaking of I wasn't as attuned to the engines and probably wouldn't have known and probably wouldn't have noticed much if there was a slight quarter throttle a quarter throttle fluttering however I can tell you however I can tell you for sure that if you're wrong if you're running A high rev and kit of at least 70C c's with a good pipe that will breathe pipe that will breathe then this upgrade is yeast upgrade is probably one of the easiest ones you can 1 of the easiest ones you can do And actually notice a difference.
Post by aeroxbud on Jul 16, 2021 6:08:49 GMT -5
I noticed an improvement in throttle response when I fitted them. Much more responsive.
Post by lunatuck on Jul 16, 2021 8:56:14 GMT -5
Thanks for the info. I’m feeling like it’s a no brainer.
