Post by ziginc on Jul 17, 2021 9:05:58 GMT -5
Ok I have a gy6 50cc. New stator new carb new battery new coil new cdi new starter new gas. Has spark but wont start. It also gets gas.
Post by sToRm on Jul 17, 2021 9:17:30 GMT -5
Check your grounds are properly grounded. Check spark plug. Check kill switch and brake light wires on brake levers. Try spraying a little ether/carb cleaner into the carb intake.
Post by FrankenMech on Jul 17, 2021 10:14:38 GMT -5
Fuel, properly timed spark, proper air fuel mix, compression.
Shotgun parts replacement is NEVER the way to work.
Download a service manual from our library here and go through the troubleshooting chart step by step. DO NOT skip any steps.
Post by milly on Aug 1, 2021 7:00:31 GMT -5
I had one where spark plug worked when testing but put back in would not work.Put new one in and fine.
Post by scooter7878 on Aug 2, 2021 18:35:20 GMT -5
I had one where spark plug worked when testing but put back in would not work.Put new one in and fine. . I've also had that with the cheap plugs from Amazon. I ordered a carb one time and it came with a plug. Mine was old so I figured I'll throw this one in for a bit till I Grab a ngk. Well a day later running like shit and sparking from plug when out there was a hair line crack in porcelain u couldn't really see by electrode. Banged in a ngk issue fixed
Post by GrumpyUnk on Aug 4, 2021 9:43:24 GMT -5
ziginc.... Take off ALL the new stuff. VERIFY that it will start with the old parts re-installed. Put ONE new part on at a time. Verify it will still start. Add more, one at a time, verifying. In theory, you should find the one part that is causing it to fail to start. IF you bought the 'Orange Performance Coil/CDI/PLUG' you are wasting your $$, IMO. They are not very good, nor very reliable. Old cheap stock parts are better, AFAIK. Carbs seem to be a crap shoot. Some are fine, out of the box, while others seem to have loose/missing parts, and possibly junk in the float bowl or passages. You don't know until you install.
tom
