Post by scooter7878 on Jul 19, 2021 16:15:58 GMT -5
Can anyone tell me I bought a airsal piston and the rings came installed on the piston does this mean the factory set the ring end gap or does it need to be checked I don't see why they would install them if it wasn't bc removing them from Piston to check it is always a chance of damaging the rings
Post by snaker on Jul 19, 2021 16:43:10 GMT -5
The rings should be sized correctly to the piston, especially if they came with the piston. If there were any question, you would buy new rings to match.
The ring end gap is adjusted to fit the cylinder. Take the rings off the piston and insert into the cylinder, then measure and adjust gap. Many video's available
Post by scooter7878 on Jul 19, 2021 16:52:54 GMT -5
I know how to do it I just wanted to know if I bought a cylinder and piston kit could I assume bc the rings were installed on piston out of the box if they were gaped already by manufacturer or do I have to take them off the piston. I can't understand why they would install them for u to have to remove them to gap and reinstall
Post by scooter7878 on Jul 19, 2021 16:56:34 GMT -5
All the cheap kits I bought they didn't come installed and I gaped them I wasn't sure bc this is a name brand kit and they came pre installed if the manufacturer does it with the kit
Post by Zino on Jul 19, 2021 17:37:36 GMT -5
Airsal is just on the edge of being a big name
Double checking cannot hurt but not checking could .
We have had the bigger names have casting differences and send the wrong combo of parts .
claydoh
Post by claydoh on Jul 19, 2021 18:13:32 GMT -5
My Airsal kit did NOT have the rings pre-installed, they were in a separate little plastic pouch. I'd wonder if you got a returned item, or one someone fiddled with it.
Just check them.
Post by scooter7878 on Jul 19, 2021 19:33:24 GMT -5
I just contacted stg he said he started doing them himself bc he had ppl not doing it right and messing them up now weather he gaps them or just clocks them idk but he said it's ready to go but I may gap them just to be sure
claydoh
Post by claydoh on Jul 19, 2021 19:42:21 GMT -5
Actually, that makes a fair bit of sense, then. My kit is the complete Airsal all-alloy cylinder and piston kit, not STG's Airsal piston in a stock-style sleeved cylinder.
Post by scooter7878 on Jul 19, 2021 20:18:36 GMT -5
Post by scooter7878 on Jul 19, 2021 20:21:11 GMT -5
Actually, that makes a fair bit of sense, then. My kit is the complete Airsal all-alloy cylinder and piston kit, not STG's Airsal piston in a stock-style sleeved cylinder. . Would u trust him or remove them and check this is my first buy from him but he seems to know his shit and he's very responsive with getting back idk removing the rings and reinstalling them is kinda a pain and I'm worried abt possible damaging a ring on the way off
Post by captincvmn on Jul 20, 2021 5:37:26 GMT -5
I asked my friend Stevie Wonder and he said his friend Ray Charles agreed, the gap looks ok from the factory.
Kidding aside, I got a Naraku set and gapped the rings, found out I had two feeler gauges stuck together. Oops. Too late.
Next cylinder was a Stage6 and I got out the rings and installed them as is.
Post by 90GTVert on Jul 20, 2021 19:04:10 GMT -5
If he is responsive, then I would ask directly if the rings were gapped or just installed. STG has been around awhile and I don't recall anything that would make me not trust them, so if told that they were gapped before installation then I'd probably believe it. I would hope that anyone that knows engines would not install rings and not check the gap first when selling parts. Most of the time it's right or at least close, but not every time. If all a seller wanted was to make sure the rings went on in the right order, that could be done without installation and just labeling/instructions. I wouldn't expect them to be installed for clocking purposes, because I wouldn't trust them not to move.
Post by scooter7878 on Jul 20, 2021 20:34:20 GMT -5
If he is responsive, then I would ask directly if the rings were gapped or just installed. STG has been around awhile and I don't recall anything that would make me not trust them, so if told that they were gapped before installation then I'd probably believe it. I would hope that anyone that knows engines would not install rings and not check the gap first when selling parts. Most of the time it's right or at least close, but not every time. If all a seller wanted was to make sure the rings went on in the right order, that could be done without installation and just labeling/instructions. I wouldn't expect them to be installed for clocking purposes, because I wouldn't trust them not to move. . That was my thinking also bc they were clocked right he said he gaps them so he has been very responsive throughout the whole order process
Post by GrumpyUnk on Jul 21, 2021 12:29:03 GMT -5
If you want to KNOW, there are two ways: check them for proper gap, OR put it together and see what happens. If someone made a mistake in measurement, you will(may) find out, but you won't like the results. I have no reason to doubt the vendor, but the one time you DON'T check is the time someone was a bit sleepy or thinking of something else when doing the checking. At least that's been my experience. Again, nothing against the vendor. Stuff happens, and it can't hurt to check. IMO. tom
