Post by will on Aug 1, 2021 14:30:24 GMT -5
Hi guys, need a little advice. Just removed the stock oil injection pump and added 40:1 fuel mixture but can not drain carb fuel due stripped screw. Will it be ok to try to start with old gas in carb? Thanks
Post by Zino on Aug 1, 2021 15:29:21 GMT -5
Yes there is still oil in cylinder from before you took the pump out the bowl will empty in 2 miles . If you want to be extra cautious just add a couple drops into the carb intake
Post by captincvmn on Aug 1, 2021 20:10:40 GMT -5
Or take that carb off completely and turn it upside down. Mines got two hoses and the throttle cable. Basically being held into the rubber boot with a Phillips head screw clamp.
On the other hand, since you had straight gas in the tank previously, the gas in the carb is also straight gas since the injection is post carb into the intake tract.
Post by Lucass2T on Aug 3, 2021 8:34:53 GMT -5
Put the bike carefully on its side, fuel will leak out by itself that way.
