Post by domvito on Aug 3, 2021 21:10:19 GMT -5
So my 08 wildfire finally got a big bore kit installed!! (had 8k miles on original gy6 50cc piston)
Anywho. Im looking to get peak performance an was wondering what you guys are running via your pilot an main jets!
Thanks in advanced!
Main is 95 Pilot is 40
My rollers are 6g(if that helps any)
running/starting ok. However it putters a bit from a complete stop.
Post by scooter7878 on Aug 3, 2021 22:34:35 GMT -5
Try a 36 or 38 idle jet have u played with the mixture screw yet? Im in Florida sea level when I used to run a cvk carb I ran 35 to 38 idle and 87 to 95 depending on the set up. U want to find the idle jet that when u get the idle and to about 1/8 throttle feeling good the mixture screw is between 2 to 3 turns out. After about 1/8 throttle ur in the needle jet and the needle clip adjustment would be in play to about 3/4 throttle. I found 36 and 38 idles worked best for me
Post by scooter7878 on Aug 3, 2021 22:36:33 GMT -5
Buy name brand jets the Amazon and ebay cheaper ones I find do not work as well I can nvr find the right feeling jet than I buy a name brand and it feels great
Post by jbjhillbilly on Aug 3, 2021 23:19:32 GMT -5
JetsRUs is your friend
Post by domvito on Aug 4, 2021 10:49:58 GMT -5
Hey thanks ill def check that out!!! Appreciate your advice!!!!!
