Post by Critter from the Rock on Aug 9, 2021 14:44:01 GMT -5
I'm considering changing my starter clutch gear but it's not slipping it seems to be in a bind. I have tried a couple of different batteries but they will not turn the motor over fast enough and kick starting seems to have a lot of problems too could it be something else in a bind or you think it sounds like it has to be the starter clutch
Post by scooter7878 on Aug 9, 2021 14:56:11 GMT -5
Will it start with kick start eventually or u can't ever get it started?
Post by scooter7878 on Aug 9, 2021 14:57:54 GMT -5
Will it start with kick start eventually or u can't ever get it started? . Take the fan cover off and plug out if u can turn motor over freely than I'd say it's the starter clutch only resistance u should feel is from the valve springs
