Post by x7rocks on Aug 14, 2021 16:52:09 GMT -5
youtu.be/bBTHPRCJUQQI didn't really like the options of batteries for the price of these scoots, so I gave this battery a try. Let me know what you think
Post by aeroxbud on Aug 14, 2021 18:23:12 GMT -5
This was all the rage in the early 2000's. When the 12v cordless drills came out. They didn't have a very high CCA, but if your kick starting anyway, it's fine. 👍
Post by x7rocks on Aug 14, 2021 18:30:36 GMT -5
This was all the rage in the early 2000's. When the 12v cordless drills came out. They didn't have a very high CCA, but if your kick starting anyway, it's fine. 👍 I love it so far. Consistent fast cranking and the electronics seem to be handing it very well. And a tiny bit of weight savings to boot 🤪
Post by 65grendel on Nov 11, 2021 18:33:51 GMT -5
Have you had to charge the pack at all?
Post by Zino on Nov 11, 2021 19:18:12 GMT -5
x7rocks that is a genius hack. do you leave it hooked up all the time or just for starting ?
Post by x7rocks on Nov 12, 2021 11:26:21 GMT -5
x7rocks that is a genius hack. do you leave it hooked up all the time or just for starting ? Mostly for starting but I do leave it when running, I did add a stronger Fuse just in case of anything and have had good luck so far with it.
Post by oldgeek on Nov 12, 2021 13:01:54 GMT -5
I was looking into doing that for my custom build a while back and still may, but I would not use the scooter charging system to charge the lithium battery pack. Beware there may be charging issues if you use the scooter charging system/regulator to charge it. The charge/discharge of lithium batteries is very picky. There is a circuit board on the lithium battery pack that controls charge/discharge. Looking at the pictures you can see multiple contacts on the battery, charger and tool. For the battery B+ and B- are marked on it and are the far left and far right contacts. The charger uses multiple contacts to charge and monitor the battery while it is charging. The monitoring of the battery pack during charging is necessary to prevent overheating and potentially a fire from occurring. You dont want a lithium battery fire under your seat while you are riding.
Post by x7rocks on Nov 12, 2021 15:04:15 GMT -5
Have you had to charge the pack at all? About 3 4 times I've had to charge it.
Post by x7rocks on Nov 12, 2021 15:06:04 GMT -5
I was looking into doing that for my custom build a while back and still may, but I would not use the scooter charging system to charge the lithium battery pack. Beware there may be charging issues if you use the scooter charging system/regulator to charge it. The charge/discharge of lithium batteries is very picky. There is a circuit board on the lithium battery pack that controls charge/discharge. Looking at the pictures you can see multiple contacts on the battery, charger and tool. For the battery B+ and B- are marked on it and are the far left and far right contacts. The charger uses multiple contacts to charge and monitor the battery while it is charging. The monitoring of the battery pack during charging is necessary to prevent overheating and potentially a fire from occurring. You dont want a lithium battery fire under your seat while you are riding. Always good to have input on this. I was curious if you may know of a small control board or maybe even a stand alone regulator to control any current that may find its way to the battery installed. So far it's 450 miles with the battery installed and have had good luck, but would like to mitigate any issue in the future.
Post by 65grendel on Nov 12, 2021 19:55:05 GMT -5
I was planning on running a ignition without a charging circuit and this makes me wonder if it’s viable option for lights? A dewalt 9 ah 20v will run a led 5000 lumen work light for 8 hours on medium setting.
Post by FrankenMech on Nov 12, 2021 22:07:50 GMT -5
Use a sealed lead acid (SLA) battery like from an emergency light or computer UPS unit. The scoot electrical system is all wrong for a cordless tool battery of any type.
Post by 90GTVert on Nov 13, 2021 15:19:01 GMT -5
ryan_ott uses SLA batts as mentioned above and I've rode with him at car shows for hours without him having trouble, though he has switched them out part way through at times since he carries a spare just to be safe. He'd had to give you the specifics, but his lights are low watt LED in the Zuma and he uses an electric water pump. This is with no charging, using a Malossi ignition. Charging anything if you go to racing setups seems to be tough anyway. My MVT doesn't seem to want to regulate. It will run 17V or so if I don't turn more lights on to tame it while cruising. I haven't tried a lot of regulators, but Yamaha and Chinese scoot regulators aren't doing it for me. From some reading and other comments here, high RPM setups sound like they're prone to these things. That may make even more argument for not even bothering with charging for high rev stuff if you just want to ride a couple of hours at a time.
Post by ryan_ott on Nov 13, 2021 17:03:30 GMT -5
As mentioned I’m using SLA 12V12ah battery. I modified the original battery box and fit this one in the same location. With the electric pump, leds all around and a few gauges I only have a 1.7a draw so I really should be fine going for 4 hours easily. Even when I change the battery out it’s always better then 50% charged.
Post by benji on Nov 13, 2021 17:17:18 GMT -5
Brooooo I would not do this unless you aren't running a charging system. Happypancake (I think) had a lithium ion and it caught fire, I would carry a fire extinguisher. Really, I would go back to a "normal" batt.
Post by Happypancake! on Nov 13, 2021 18:57:13 GMT -5
Brooooo I would not do this unless you aren't running a charging system. Happypancake (I think) had a lithium ion and it caught fire, I would carry a fire extinguisher. Really, I would go back to a "normal" batt. Not me. That was lilpinney who’s ruck went up in flames
