Post by steve1297 on Oct 18, 2021 21:21:31 GMT -5
And man, it is quick with this Naraku set up. 0-40 in 8.5 seconds. RPM stays at 7800 roughly, between 40 and 50mph(top speed is still 49mph).
Post by scooter7878 on Oct 19, 2021 0:40:45 GMT -5
And man, it is quick with this Naraku set up. 0-40 in 8.5 seconds. RPM stays at 7800 roughly, between 40 and 50mph(top speed is still 49mph). I get the same 0 to 40 times I just get a higher top speed bc I get gears and a little higher rpm's I don't think we can ask for much more out of a qmb my buddy has a 155cc with exhaust,cam,26mm round slide carb,uni air filter,and a ssp cvt kit and his 0 to 40 times are around 6 to 7 sec
Post by steve1297 on Oct 19, 2021 2:02:37 GMT -5
And man, it is quick with this Naraku set up. 0-40 in 8.5 seconds. RPM stays at 7800 roughly, between 40 and 50mph(top speed is still 49mph). I get the same 0 to 40 times I just get a higher top speed bc I get gears and a little higher rpm's I don't think we can ask for much more out of a qmb my buddy has a 155cc with exhaust,cam,26mm round slide carb,uni air filter,and a ssp cvt kit and his 0 to 40 times are around 6 to 7 sec Yep. My top speed is absolutely limited by the gearing. How hard is it to install those pre pressed gears?
Post by scooter7878 on Oct 19, 2021 5:17:23 GMT -5
I get the same 0 to 40 times I just get a higher top speed bc I get gears and a little higher rpm's I don't think we can ask for much more out of a qmb my buddy has a 155cc with exhaust,cam,26mm round slide carb,uni air filter,and a ssp cvt kit and his 0 to 40 times are around 6 to 7 sec Yep. My top speed is absolutely limited by the gearing. How hard is it to install those pre pressed gears? . eBay seller scooters to go has pre pressed for 50 bucks. But if u have a press it's not hard and I'm sure it could be done some other way but I just buy them pressed from scooters to go
