Post by milly on Aug 18, 2021 9:05:18 GMT -5
Anything that will remove the white hand painted stuff that wont affect the blue underneath which has not even been keyed for the White to stick to it. Thank you
Post by jloi on Aug 18, 2021 20:52:13 GMT -5
OMG!!
Post by FrankenMech on Aug 18, 2021 21:39:54 GMT -5
White brushed on paint? Is it latex house paint?
I think identifying the paint type would be a first step.
Post by yambw’s on Aug 19, 2021 5:56:53 GMT -5
Gently gently heat gun
Post by jloi on Aug 19, 2021 9:17:33 GMT -5
PO must have done that for a "protective barrier" .
for the fender , that might flex/bend , maybe ; maybe some of it would just kinda pop off if you flex the fender .
Post by jackrides on Aug 19, 2021 12:38:06 GMT -5
A pressure washer, starting with the lowest pressure nozzle. Or, start with a hose on highest pressure nozzle.
Post by FrankenMech on Aug 19, 2021 15:50:29 GMT -5
'Goof Off' a tar and gum remover solvent sold here in the US will supposedly remove dried latex paint according to the label.
Post by milly on Aug 20, 2021 9:49:30 GMT -5
'Goof Off' a tar and gum remover solvent sold here in the US will supposedly remove dried latex paint according to the label. Sure they sale goof off over here will check scooter over weekend when back from work.
Post by milly on Aug 20, 2021 9:52:20 GMT -5
A pressure washer, starting with the lowest pressure nozzle. Or, start with a hose on highest pressure nozzle. Good idea thank you
Post by FrankenMech on Aug 20, 2021 12:40:15 GMT -5
Did you ever figure out what type of white paint that was?
Anything you can do to peel the paint off will help before you resort to solvents or sanding is good.
Post by jloi on Aug 20, 2021 13:44:41 GMT -5
milly , I just remembered . when I was restoring the vise I ended up at one point using oven cleaner. worked great. cheap . you could get a can and try it on some other old scooter plastics and see if it melts it or what .
Post by milly on Aug 20, 2021 15:08:05 GMT -5
Not had chance yet been away working.
Post by jloi on Aug 20, 2021 22:47:19 GMT -5
milly; if you do the oven cleaner , be real careful. it's nasty toxic to breathe or get on you .
Post by milly on Aug 27, 2021 3:45:46 GMT -5
Found out the paint is a vinyl matt emulsion so will try with heat gun gently and see what gives.
Post by FrankenMech on Aug 27, 2021 18:29:13 GMT -5
Found out the paint is a vinyl matt emulsion so will try with heat gun gently and see what gives. I don't know what that is.
