Post by lilpinny on Sept 11, 2021 12:06:43 GMT -5
I use these things called dynabeads. Little beads you feed into the tire through the valve stem. www.innovativebalancing.com/mobile/The guys at the Harley shop turned me on to them. They balance the wheel for you when you ride. They work awesome. I’ve heard that they can mess up some tires, but I’ve never had a problem with it.
Post by scooter7878 on Sept 11, 2021 15:00:37 GMT -5
scooter7878 Thinking the wheel might need to b balanced. . No I agree it's def a way better ride around 30psi if ur feeling a wobble in turns especially with higher tire pressure u might have some tire cupping on ur tires in the edges I kinda have that too on my set run ur hand front to back over the tire feel if it's out of shape like if the treads are shifting when the treads cup like that high tire pressure makes it feel worse. Balance would more be a shaking or vibration at certain higher speeds. Running max pressure def makes the bike handle way different but I've always ran em like that so u guess I've adjusted my riding and got used to it I def agree 30 or 32 compared to 40 actually makes a huge difference not only speed wise but fuel mileage and handling
Post by scooter7878 on Sept 11, 2021 15:01:39 GMT -5
I use these things called dynabeads. Little beads you feed into the tire through the valve stem. www.innovativebalancing.com/mobile/The guys at the Harley shop turned me on to them. They balance the wheel for you when you ride. They work awesome. I’ve heard that they can mess up some tires, but I’ve never had a problem with it. . That's interesting I've nvr seen or heard of that
Post by jstich on Sept 13, 2021 16:44:48 GMT -5
I recall some users using bb's inside the tires to balance them somehow.Something along those lines.
