Post by vertkingbubbie on Sept 13, 2021 20:39:40 GMT -5
Recently built a 2001 old school Zuma, that did over 70+ with stock gearing. I have some changes to come soon to try and exploit a few more mph.
70cc aluminum Mxs intake 30mm carb Mxs style exhaust Full overrange Malossi delta clutch stage6 wingcooler bell Stock gears Stock ignition with malossi cdi
Post by captincvmn on Sept 13, 2021 20:46:29 GMT -5
Is the over range worth all the MPH? What rpm at 70? I’m running stock gears and for now stock cvt getting 54mph on flat at close to 10k rpm
Post by Zino on Sept 13, 2021 21:15:21 GMT -5
welcome to the forums 70 mph is smoking fast
Post by woodini on Sept 13, 2021 22:07:17 GMT -5
welcome to the forums 70 mph is smoking fast Scary fast
Post by 808ministroke on Sept 13, 2021 22:09:33 GMT -5
Noice! on a vertical too.
Post by ghostaroni on Sept 17, 2021 7:01:44 GMT -5
Recently built a 2001 old school Zuma, that did over 70+ with stock gearing. I have some changes to come soon to try and exploit a few more mph. 70cc aluminum Mxs intake 30mm carb Mxs style exhaust Full overrange Malossi delta clutch stage6 wingcooler bell Stock gears Stock ignition with malossi cdi that over range really makes a huge difference. what brand carb are you using? and what jet size?
