Post by biker4eva on Oct 4, 2021 8:28:11 GMT -5
i picked up a baotian bt49qt-20 tiger wires had been cut replaced few bits but it doesnt start its had new starter relay,battery,brake levers,handlebar switches been checked,new ignition barrel,ignition coil but wont start at all no sounds power goes to the relay but nothing come sout to the starter motor i pull brake lever in and press start button but nothing not sure if cables to the cdi are correct as haynes manual is weird to follow and cables from the alternater been spliced and not sure if there correct also hard to findf a new wiring loom that hasnt been touched
Post by scooter7878 on Oct 4, 2021 9:45:03 GMT -5
If the starter is not turning there are 2 fat wires and 2 small wires at the solonoid. One fat wire should have power at all times. One small wire should get ground when starter button is pressed. One small wire should get power when u pull the brake handle. When the two small wires get pwr and gnd the solenoid should close and the other fat wire pwr the starter. Check what ur missing on the two small wires if no ground on one of them check the starter button if no pwr on one check the brake switch and related wiring. If the little fuse by battery is blown it can give u this issue also
Post by biker4eva on Oct 5, 2021 2:32:13 GMT -5
hi i replaced the glass fuse to a blade fuse so its easier to change plus the blade has a light that shines red once blown i cleaned the starter button inside yesterday cleaned the contact pins etc it has brand new brake switches both sides as they are resi combi with brake fluid and levers the only things not been changed are the switches on the handlebars most of the cables on the loom been cut so have no idea where they go i belive one i sorted is a earth at the base of the handlebar and think another one earth is on the alternater i gotta sort out
Post by GrumpyUnk on Oct 5, 2021 9:38:59 GMT -5
Handlebar switches get rusty and dusty with time and age. You have to check for power and ground as 7878 suggested. Get a meter or a lightbulb(12V) in a socket with wires attached. Touch one wire to the + battery terminal, the other to one wire (small) on the relay. Push the START button. The bulb should light. Take the same wires, connect/touch one to the - battery, the other to the starter small wire, pull the brake lever(try both) the brake lights should light, along with the bulb in the socket. Try the other brake lever. Same result. If not, fix that. tom
Post by biker4eva on Oct 8, 2021 15:52:43 GMT -5
so ive replaced both switches and still doesnt do anything im thinking its the wiring loom to be fair
Post by scooter7878 on Oct 8, 2021 18:26:01 GMT -5
U need to put a test light between the two small terminals on the starter solenoid like grumpy said if it doesn't light than u need to test one wire should ground from starter button and one should power from brake switch it's easy enough to do and guessing just leads to parts that don't need to be replaced and hours of not finding the problem.
