Post by scrpmtl23 on Oct 12, 2021 19:37:23 GMT -5
Thanks in advance to anyone who can help. New to this forum and scooters. I purchased a 92 Razz a few weeks back. Got it running nicely but needed to change the tires because they were rotten and on their way out. I put on new tubes and tires on front and rear. Now I'm noticing what I would say is a bouncy front end which wasn't present with the old, rotted tires. It is relatively consistent while rolling but diminishes a bit at higher speed but not completely. Can anyone advise as to what might be the issue?
Post by aeroxbud on Oct 12, 2021 23:07:38 GMT -5
There is a red dot on the tyre that needs mounting by the valve stem. This is to help balance the weight of the tyre. Did you do this? You could also check the fire is balanced correctly, and the wheel is straight.
Post by scrpmtl23 on Oct 13, 2021 11:31:52 GMT -5
I did not do this! I will have to take a look at my tire and see about popping it off the bead and moving the tire to this dot. I did not notice anything but doesn't mean it isn't there. I installed Kenda tires and tubes.
Post by scrpmtl23 on Oct 14, 2021 13:30:54 GMT -5
Emailed Kenda and there is no indicator for these tires. Waiting to see if they have any more insight
