Post by dukeofspeed on Oct 15, 2021 19:35:30 GMT -5
I bought this scoot as a non runner and not knowing anything about modern scooters, can anyone give me a clue. Has no spark and starter motor won't work on the key, the brake light and indicators work. Starter works if I power it direct. The starter relay is not faulty, I have checked it. I think the immobiliser is missing? there is no aerial ring thing around the ignition switch.
Post by dukeofspeed on Oct 15, 2021 19:37:22 GMT -5
Horn also works
Post by aeroxbud on Oct 15, 2021 23:01:47 GMT -5
Peugeot are notorious for the immobiliser failing. Most seem to fit a bypass to sort it.
Post by geoffh on Oct 16, 2021 8:38:38 GMT -5
And just to eliminate it,a lot of scoots need the brake applied to activate the starter.
Post by dukeofspeed on Oct 21, 2021 15:12:03 GMT -5
And just to eliminate it,a lot of scoots need the brake applied to activate the starter. Geoff Thanks Geoff, That was it. All working, good spark, except it won't start so will investigate the fuel supply.
Post by geoffh on Oct 22, 2021 8:15:37 GMT -5
Happy to help,use the tech section to diagnose the no start problem,a short cut is to dump any old fuel and start fresh,some easy start may be needed to"jump start" the systems back to life.
Post by repherence2 on Oct 22, 2021 11:12:02 GMT -5
Check to make sure you have a ground wire to your engine.
As far as Chinarelli's and SYMs, the main ground wire connects to one of the starter bolts.
No engine ground strap = no spark.
I just went through this during my engine swap. Kicked and kicked for 30 minutes. Tried to crank it with a drill in reverse via the variator nut, broke the drill chuck retaining screw. Gave up after an hour to avoid insanity. The next morning, as i was driving back from the store, it dawned on me that the engine was not grounded.
