Post by dem1g0d on Oct 16, 2021 12:07:27 GMT -5
More recently I've noticed that my VIP Future Champion will go into 9k RPM or more very easily. Used to be only when going downhill but now is mostly on flat and especially on downhill as well. If I don't reduce speed going downhill the RPM will just continue to go up.
I can rarely get the motor to not be under 7 or 8k RPM when trying to attempt 40~ mph.
If I want to keep it low, I basically have to drive around 25 or 30mph.
Idles where it's supposed to, at 1.5k
Post by aeroxbud on Oct 16, 2021 15:27:28 GMT -5
Have you changed anything in the CVT? How many miles does the engine have? Could of just be getting run in if it's low miles. You could always try heavier rollers. But too heavy will make the engine struggle to get into the power band.
Post by 90GTVert on Oct 17, 2021 5:32:37 GMT -5
Check belt width. RPM will rise if the belt thins much.
Post by steve1297 on Oct 17, 2021 20:58:08 GMT -5
Yep. You need a new belt
Post by GrumpyUnk on Oct 18, 2021 10:35:10 GMT -5
The CVT works by varying the width between the sides of the variator and the clutch assembly. If your belt is worn, it is very likely thinner, and will not get squeezed as much to go as high up/far out in the variator, so will not do the same to the clutch(forcing the sides apart) so the gear ratio will not be as 'high' as previous. Thusly, your top speed will be lower, and the engine rpms (variator locked to the crankshaft) will be higher. I vote with the previous posts, in that I think you need a belt. Jim Beam is good, but you must sip. tom
Post by steve1297 on Oct 18, 2021 20:01:17 GMT -5
And get a nice belt, like a Bando, or some other Kevlar belt
