Post by hondajazz04 on Oct 23, 2021 21:31:26 GMT -5
Hi All, bought a non runner, Sat since 2012
180 miles, 2004 jazz 50, New batteries, cranks great, new fuel, and seafoam, what's next check spark?
Post by hondajazz04 on Oct 23, 2021 21:31:56 GMT -5
1 battery 🔋**
Post by scooter7878 on Oct 23, 2021 23:51:16 GMT -5
Spark and compression
Post by scooter7878 on Oct 23, 2021 23:55:06 GMT -5
One thing to check if u don't have spark is sometimes from sitting so long the flywheel will get a slight rust that prevents the pick up from reading. Also the cdi's go from sitting. For spark related u should be checking the cdi,coil,pick up,spark plug and grounds
Post by steve1297 on Oct 25, 2021 6:54:34 GMT -5
That carb is trash if it's been sitting since 2012. Get a new carb, put it on, change the oil, and she'll crank right up. Probably no saving that carb. You can try, but they're like $12
Post by GrumpyUnk on Oct 25, 2021 8:57:32 GMT -5
Likely carb full of de-fueled gasoline. Is now jumpbled hydrocarbons, plugging the pilot jet and possibly the main jet. Check both and emulsion tubes. Also make sure you do not have a kill switch on the kickstand. It will insure your engine remains unrunning with the kickstand extended. It can also do the same when the kickstand is folded up out of the way if defective. tom
