Post by ghastechen on Oct 24, 2021 20:50:19 GMT -5
I saw a guy selling a brand new 70cc kit because it dindt fit on his Honda Vision 50 Will it fit on my Honda X8R? Ive been looking for the engines and they are pretty similar to me But since i dont have much knowledge i decided to have sure first
Post by aeroxbud on Oct 24, 2021 22:57:31 GMT -5
We would at least need a kit name and model. And ideally a part number too.
Post by ghastechen on Oct 25, 2021 2:44:59 GMT -5
Post by ghastechen on Oct 25, 2021 20:51:23 GMT -5
Post by aeroxbud on Oct 26, 2021 6:31:55 GMT -5
In the Malossi store. It says it only fits the vision, aero, and met. So I'm guessing it's not compatible with your scooter. 😞
Post by ghastechen on Oct 26, 2021 8:56:06 GMT -5
In the Malossi store. It says it only fits the vision, aero, and met. So I'm guessing it's not compatible with your scooter. 😞 Well thats a bummer, im just waiting for further info from the guy is selling, lets hope it can fit I will disassemble my engine anyways for cleaning and porting it, ill take measurements and compare them to see if it fits Thanks a lot for the info and the help ❤️
Post by ghastechen on Oct 26, 2021 9:10:21 GMT -5
In the Malossi store. It says it only fits the vision, aero, and met. So I'm guessing it's not compatible with your scooter. 😞 The guy just told me that the kit he is selling fits on Honda AF29 and AF42 engines I hope this helps
Post by ghastechen on Oct 26, 2021 9:17:41 GMT -5
In the Malossi store. It says it only fits the vision, aero, and met. So I'm guessing it's not compatible with your scooter. 😞 Well it not fits, my engine is rhe AF49E
Post by aeroxbud on Oct 26, 2021 9:26:00 GMT -5
A lot of the different Honda dio engine parts are not interchangeable. I guess you're is another variation.
Post by ghastechen on Oct 30, 2021 21:32:47 GMT -5
A lot of the different Honda dio engine parts are not interchangeable. I guess you're is another variation. Im looking to go for a proper Malossi 70cc kit for my model, then a 17mm carb if needed, i dont think my stock one will be enough to delivery the needed fuel for the extra cc, also ordered a unrestricted CDI and a better coil, starting my project slowly, just finished restoring a 1993 Yamaha CT 50 S, now starting my Honda X8R I changed the Yamaha original piston for a Vertex one, did i make a good choice? Once again thanks a lot for the help and tips.
Post by aeroxbud on Oct 31, 2021 5:06:28 GMT -5
You can run a bigger bore on the standard carb. You won't get the same performance as a bigger carb. When I switched from a 12mm to 17.5 I got a noticeable increase in top end performance. Vertex make a good piston. As long as it's the same specification it should be good.
