Scoot Tag : Can You Be The 2022 Scoot Tag Champion?!?
Mar 1, 2022 17:18:41 GMT -5
aeroxbud and dexameth like this
Post by 90GTVert on Mar 1, 2022 17:18:41 GMT -5
The Special Tag for February is over. Congrats on the extra points and thanks to dexameth for participating. Updated scores are below, so make sure you use them when the next tag is posted.
Special Tag Points
dexameth : +7 points (#1, #2)
Scores
dexameth: 30 (3)
chadbullet : 17 (12)
Captincvmn: 17
FatKid: 11
Now, a new Special Tag. This one will last for the entire month of March. There were three "Tougher Tags" that must have been too tough in January. Those were active for February, worth one additional point than the previous month. Dexameth got 2 of them, but there's one left. That's now worth not 1, but 2 additional points! I'm adding a couple more as well. These are not limited to one person, so even if you see someone post it, get it for yourself if you can.
Here are the active Special Tags for March and the new point totals :
1) Your scoot with it's tire parked on a social distancing marking. You know, those 6ft apart markers. It must be obvious that it's a social distancing marker and not just a painted line or homemade sign on paper and the like..
(5 points)
2) Your scoot with a building or sign with "endodontist" or "endodontics" on it. I lost a filling and just found out that I need a root canal today, so why not.
(1 point)
3) Your scoot and a sign promoting any event with "spring" in it's name. It can be part of one word, like "Springfest" for example.
(2 points)
4) Your scoot with someone dressed mostly in green sitting on it. It can be you, a friend, a stranger...
(2 points)
Remember to post the Special Tag number so I'm sure what you're posting. Must be posted before midnight (Eastern) on 3/31/2022. You can only do each Special Tag once. There's no limit to how many members can get the tag, so even if you've already seen it posted, you can go grab your own pic and still claim the points.
DO NOT UPDATE YOUR SCORE WITH SPECIAL TAG POINTS FROM THESE. I WILL UPDATE SCORES AFTER THE END OF THE MONTH.
Here are the current scores one more time so they're easy to find for whoever grabs the next tag.
Scores
dexameth: 30 (3)
Captincvmn: 17
FatKid: 11
Special Tag Points
Scores
dexameth: 30 (3)
Captincvmn: 17
FatKid: 11
(5 points)
(1 point)
(2 points)
(2 points)
Scores
dexameth: 30 (3)
Captincvmn: 17
FatKid: 11
