Post by x7rocks on Jan 21, 2022 12:09:45 GMT -5
messenger
Post by messenger on Jan 21, 2022 13:41:39 GMT -5
This should be interesting...
Post by aeroxbud on Jan 21, 2022 15:49:18 GMT -5
Going to be an interesting build.
Post by jackrides on Jan 22, 2022 13:29:36 GMT -5
WOW! 2 questions. Visually the cylinders appear different heights? What is the hole between the cylinders? Can't wait to see how this progresses!
Post by x7rocks on Jan 23, 2022 13:45:15 GMT -5
WOW! 2 questions. Visually the cylinders appear different heights? What is the hole between the cylinders? Can't wait to see how this progresses! It allows you to put the crank adapter. He machines the crankshafts with a little adapter to connect the two,the firing order would be 180 degrees
Post by pete130 on Jan 28, 2022 7:44:38 GMT -5
WOW! 2 questions. Visually the cylinders appear different heights? What is the hole between the cylinders? Can't wait to see how this progresses! It allows you to put the crank adapter. He machines the crankshafts with a little adapter to connect the two,the firing order would be 180 degrees This build will definitely be one to see first done can't wait, ive always wanted to do one as well
Post by x7rocks on Feb 17, 2022 19:07:05 GMT -5
It allows you to put the crank adapter. He machines the crankshafts with a little adapter to connect the two,the firing order would be 180 degrees This build will definitely be one to see first done can't wait, ive always wanted to do one as well This is definitely going to be a slow process. Shipping my cranks to Germany is taking forever
Post by pete130 on Feb 17, 2022 20:58:14 GMT -5
This build will definitely be one to see first done can't wait, ive always wanted to do one as well This is definitely going to be a slow process. Shipping my cranks to Germany is taking forever Shipping anything any were at moment is frustrating slow lol
