Post by kinggorilla on May 8, 2022 14:38:30 GMT -5
Hi Guys... first, thank you in advance for you help and input.
So I recently bought a 2005 Zuma (2s 50cc) with only 2k miles on it, it will totally be a zip around town ride, not my primary vehicle.
I have already purchased the following: [INSTALLED] Malossi Variator Stage6 Torque Control MKII clutch
Malossi Wing Bell Yasuni R exhaust
[PURCHASED BUT NOT INSTALLED] 70cc Stage 6 MKII kit (Not installed yet) Dellorto RACING Black Edition 21mm Carb cable
I am contemplating what crankshaft to get to match the cylinder kit and I am thinking staying Stage6 and going with the HPC Crankshaft (I assume they pair well together) What are your guys thoughts/experience on that crankshaft? Should I consider another, if so why?
Besides the Crankshaft, what would you all suggest next? Reeds? Intake? Am I missing anything?
Post by repherence2 on May 8, 2022 17:23:03 GMT -5
temp gauge, jet kits (pilot and main), tachometer and a set of tuning roller weights.
Post by Zino on May 8, 2022 21:43:03 GMT -5
temp gauge, jet kits (pilot and main), tachometer and a set of tuning roller weights. Everything Repherence says and I would get some gears Athena makes some 14/42 gears that would put you at a great Final Ratio that you would still get good take off and your Top end would push over 60 mph with the other parts you have .
Post by aeroxbud on May 9, 2022 6:20:04 GMT -5
Which stage 6 out do you have? There is a Stage6 Sport Pro MKII Cylinder Kit, and a Stage6 70cc Racing Cylinder MKII. They are quite different. I had that crank in my old aerox, never had a problem with the stage 6 racing kit fitted.
Should be a fun set-up.
Post by kinggorilla on May 10, 2022 13:34:40 GMT -5
Which stage 6 out do you have? There is a Stage6 Sport Pro MKII Cylinder Kit, and a Stage6 70cc Racing Cylinder MKII. They are quite different. I had that crank in my old aerox, never had a problem with the stage 6 racing kit fitted. Should be a fun set-up. I got the Stage6 Sport Pro MKII, I thought the Race kit might be more of a race only kinda situation and maybe to temperamental.
Post by kinggorilla on Jun 8, 2022 10:05:29 GMT -5
Well she's all reassembled, built like my sig says, and she's runnin like a scalded ape!
Post by 808ministroke on Jun 9, 2022 1:30:55 GMT -5
agree Wirth what rephrence said, but if money is the issue grab a cheap tachometer for 20 on ebay and you could start tuning cvt with out any more$ just by modifying the rollers you already have, 90gt did a video on that , you can remove inner metal part and save some off, or add foil to increase weight, wait... you would also n3ed to spend 20 on a digital scale, I forgot nit everyone already has those... glad to hear it all went together well! with the m2 sport you should be okay with stock crank👍
Post by repherence2 on Jun 10, 2022 23:11:42 GMT -5
im happy for you! run 'um Hard.
** do you have a temp gauge? **
Post by kinggorilla on Jun 11, 2022 2:38:02 GMT -5
I do, I got the Polini Tach and 2 temps gauge. Reads to like 400°+ so it’ll work well.
