Post by 503ruck on May 24, 2022 22:18:33 GMT -5
I own a 2015 Honda Ruckus. I'm wanting to clean up the engine/carb area. Change out tubing to colored see-through tubing, delete unnecessary wiring, take apart harnesses and add loom to cover wires, etc.
Any tips and tricks you guys have done feel free to comment and share.
Post by jbjhillbilly on May 30, 2022 13:06:02 GMT -5
The PAIR valve can be deleted, and blocked off. mnnthbx.com/product/pair-valve-block-off-honda-ruckus-met/There’s a LOT of other customization you can do as well, but deletions mean modding other systems as well (airbox delete means rejetting the carb, etc). ETA: I’d seriously think about leaving the harness along unless you NEED to do something to it. More issues is scooterland with electrical shorts than you can shake a stick at.
Post by sToRm on Jun 20, 2022 19:08:33 GMT -5
Unless you’re doing a wire tuck inside the rear frame, it’s best to leave the harness as is. There’s nothing to gain by removing wires that are essential to the functionality of your Ruck. As far as tubing, I use clear tubing only for the fuel line. I also use silicon hoses for the radiator. Not sure if clear tubing can withstand the heat of the coolant. Alternatively, you could cut your stock floorboard in half and use the rear section to cover/hide all that stuff.
