Post by stage6zuma on Jun 5, 2022 16:22:59 GMT -5
I have done hours of reading and haven't found exactly the answer I'm looking for. I want to build my 2001 pre bug into a very low rpm, high torque wheelie machine. Between the 2 cylinders which has the best low end performance? TOP black trophy or polini sport bore. Want to pair it with a stage 6 Street pipe, polini sport pipe, and haven't ruled out the technigas sport pipe. And carb upgrade if needed.
Post by aeroxbud on Jun 5, 2022 16:53:22 GMT -5
I would go with the Polini or Malossi sport. A little bit better quality. The Polini also has the better sealing method with the sealing ring. Which can also be reused. I ran a Polini sport on my vertical Minarelli with great results. It's a very durable cylinder.
Post by Lucass2T on Jun 5, 2022 18:39:25 GMT -5
They are basically all the same. I'am not sure what pistons both use. I think Polini uses Asso, Top Performances Meteor? But both are just plain and simple cast iron 47mm bores which are perfect for the stuff you want to do with it. You might wanna consider a DR kit too. Those are bullet proof.
