Post by student on Jun 5, 2022 18:21:38 GMT -5
gy6 has spark, display shows no power on dashboard, I can kickstart it, I just cleaned the contact leads and charged the battery, had a problem earlier where only the left handlebar would let it start electrically, recently replaced the starter. putting a screwdriver in between the starter relay makes in electrically start.
Post by aeroxbud on Jun 5, 2022 18:27:19 GMT -5
Have you checked the main fuse by the battery? I had a similar thing happen before, and that's what it was.
Post by student on Jun 5, 2022 18:52:26 GMT -5
I checked the pin connector with a muti meter and 1 pin lights up when connected to both - and + power the other one lights up when brake and start button is held down for both + and - the - light up the probe less.
Post by student on Jun 5, 2022 18:53:11 GMT -5
yes, I checked fuse and it was fine replaced it anyway no difference.
Post by GrumpyUnk on Jun 6, 2022 9:54:26 GMT -5
Student: "I checked the pin connector with a muti meter and 1 pin lights up when connected to both - and + power the other one lights up when brake and start button is held down for both + and - the - light up the probe less."
Sorry. I have no idea what that means.
The brake lever switches provide power in most designs that is then routed through the starter button and then to one side of the starter relay. The other design supplies brake light power to one side of the relay, and then the starter button supplies ground to make the relay close. If the brake lever switches BOTH work to light the brake light, then the switches are good. If not, check that switch that does not cause brake lights to glow. Check for power to one of the starter button switch leads when you pull the brake lever. Then if you have that, check for power coming from the starter button switch with both brake and starter switches closed. Adding punctuation or at least taking the time to express your thoughts makes assistance more likely.
Post by student on Jun 6, 2022 19:34:30 GMT -5
The brake on the starter button side does not light up the brake light the majority of the time (multiple starts) what happens is the starter side brake switch won't light up until I have squeezed the left side brake a few times, pulling the brake does not seem to affect the starter button connections they all show power with the black and white cable being weak, not sure if this is worth mentioning my turn signals do not work at all both sides.
Post by student on Jun 6, 2022 20:13:52 GMT -5
Well, I found this broken looking thing in it
Post by GrumpyUnk on Jun 7, 2022 8:13:07 GMT -5
I wish the photos were focused as they are not very useful to determine what is being imaged much less if there is something wrong. I do not know what I am supposed to see. tom
Post by student on Jun 26, 2022 15:17:30 GMT -5
turns out it was loose positive wire to my battery I crimped the wire myself and guess I did it a bit wrong, pulling and moving the wire around makes it work, the picture was apparently my blinker flasher relay I replaced it and my turn signals started working again.
Post by mrbensteele on Jul 24, 2022 21:39:57 GMT -5
I had the same issue. First i couldnt start it via the electric ignition if my tail light was connected (had broken wires), fixed it by soldering the wires, could start if the tail light was unplugged. Then the bike suddenly wouldnt no matter what I did though kick start worked. I discovered the Starter Solenoid was the cause plus my Fuse was blown. I did find that there was a burn mark on my Voltage Regulator but it still functioned. I ended up replacing the regulator, the fuse, CDI and Solenoid, and my Starter just because mine was rusty.
Each part is cheap but start with the Starter Solenoid then the Regulator and check the fuse. Check for broken wires at the battery and bother ends of the fuse holder.
Good luck
Post by antluc573 on Jul 24, 2022 21:49:40 GMT -5
QuoteEditlikePost OptionsPost by antluc573 on less than a minute ago Hey whats the word world, I honestly don't know where to begin. This is my first time joining a forum or even reaching out like this for help but I'm really scratching my head on this one. So, recently my 2019 Baodiao 50cc scooter was stolen and it is crazy how i was able to get it back because i dont like involving the police in ANY of my affairs. so the bastard that stole my bike took my alarm system off and the dumbass cut the wires on my ignition!! I know a idiot! anyways he had a jumper wire on the ignition harness and when i went to take the wire out< somehow i touched another wire in the harness that cause a spark and popped the only fuse that is used on the bike. now i have no spark whtsoever! i have changed he coil because it actually needed to be replaced. I also replaced the cdi box thinking that when the wires touched it might have shorted out the cdi but still no spark. the engine turns over but no start. im completely lost and really need to get my bike back on the road. if anybody can please help me figure this dumb ass shit out it would be greatly appreciated! Thanks
Post by aeroxbud on Jul 25, 2022 8:23:22 GMT -5
QuoteEditlikePost OptionsPost by antluc573 on less than a minute ago Hey whats the word world, I honestly don't know where to begin. This is my first time joining a forum or even reaching out like this for help but I'm really scratching my head on this one. So, recently my 2019 Baodiao 50cc scooter was stolen and it is crazy how i was able to get it back because i dont like involving the police in ANY of my affairs. so the bastard that stole my bike took my alarm system off and the dumbass cut the wires on my ignition!! I know a idiot! anyways he had a jumper wire on the ignition harness and when i went to take the wire out< somehow i touched another wire in the harness that cause a spark and popped the only fuse that is used on the bike. now i have no spark whtsoever! i have changed he coil because it actually needed to be replaced. I also replaced the cdi box thinking that when the wires touched it might have shorted out the cdi but still no spark. the engine turns over but no start. im completely lost and really need to get my bike back on the road. if anybody can please help me figure this dumb ass shit out it would be greatly appreciated! Thanks You should really start your own post in the problems section. Otherwise this post will get lost, and nobody will know what problem you have. If you removed the jumper cable it won't run without the alarm fitted.
