toto50
Bring the Motherf***king Ruckus!
Post by toto50 on Jun 10, 2022 14:27:08 GMT -5
Going to be purchasing this Airsal kit with a 50mm head as well. On the rocker arm assembly what is the dimension I need to fit?
Post by GrumpyUnk on Jun 18, 2022 8:51:47 GMT -5
Airsal should note in the description if there is a need for different rocker arm assemblies upon installation.
If you are considering valve stem length, 64/69mm, then again, Airsal should note the valves installed, and thus the rocker arm assembly that matches. I may not have answered what you are asking... tom
